Planting Sunflowers
dink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dink Quote  Post ReplyReply Direct Link To This Post Topic: Planting Sunflowers
    Posted: 07 Mar 2018 at 3:02pm
Has anyone planted sunflowers with an AC 72? Looking for info on what Deere plates you used with sprocket combos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 3:15pm
I have a half bushel of seeds I saved from last fall. I have a JD 7000  and put a handful in  bean meter and they seemed to go thru fine. I'm going to no till a bunch into my CRP ground this spring.
 They would probably work OK in the corn meter too, with the finger pick ups.
 Hope you figure out what you need for a plate. I have a 5 gallon bucket full of plates here, but never went thru to size them and don't even know for sure what they fit. Seems like I got them when I bought a scrap 4 row Allis planter many years ago.
Edited by CTuckerNWIL - 08 Mar 2018 at 8:22am
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:01pm
I have a half bushel of seeds I saved from last fall. I have a JD 700  and put a handful in  bean meter and they seemed to go thru fine. I'm going to no till a bunch into my CRP ground this spring.
Works very well with Deere finger pickups. Over the years I probably did 125-150 acres. I’m a huge fan of Deere’s planting equipment.
Edited by victoryallis - 07 Mar 2018 at 7:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2018 at 8:25am
That's good to know Victory. I may not even switch to bean meters this spring. One is broken and needs replaced, and I have been sowing soybeans in my plots with Grandpa's old Cyclone seeder and just dragging them in with the 4 wheeler.
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 5:55am
Go to--     https://lincolnagproducts.com/support/
Download their 2018 Info Packet PDF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 7:34am
what does Darrel in ND use to plant his?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 8:20am
If you plant salted seeds . . . do you get already salted when you pick them? LOL
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2018 at 10:03am
Well, if that isn't enough, maybe the combine SHAKER will add more to your suit your taste!Smile
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 8:23pm
plant mine with a 3 point fertalize spreader on my 45 diesel wanted to have them in the ground by mid feb.but we had a monsoon that month.....
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:57pm
Mine get planted with a Deere 494 planter, I think I run the Lustran B7-24 plates. These are made for medium flat corn but they do just fine on sunflower seeds. You don’t have to use the specific plate for a seed, if you have a bunch of plates you can use one that the seed fits in. It’s not as precise as the plate made for it but it works. Just make sure to turn the plate by hand with some seeds in the box to make sure your not grinding up the seed!
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 9:00pm
dink,are you planting the sun flowers for your honey bees?if so what variety are you planting?
