Planter for a WD45 |
KC-WD45 ![]() Silver Level ![]() ![]() Joined: 11 Oct 2010 Location: Kansas City Points: 114 |
![]() ![]() ![]() ![]() ![]() Posted: 24 May 2011 at 1:32pm |
What would be a good conventional till planter for a WD45? I borrowed a IH 400 air planter last week to plant beans but of course had to use a different tractor because of the hydraulics. I would like to find a 4 or 6 row that would work well with my tractor. I'm sure I would have to modify it if I want hydraulic markers but what would be a good start. I saw a AC 333 six row that went for about $700 locally and I see plenty of the IH 400 air planters for about $500 but thought I would get some opinions. Right now I'm farming 20 acres but hope to pic up more in the future. By the way my beans are up!
John (C-IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
They are getting to be scarce, but a AC SC planter or a JD495 would be the planter of choice from that era. Most modern planters require more more hydraulics that the WD45 can supply. The next step up would be a JD1240 and then a JD7000. The advantage of the 7000 is hydraulic markers, but you may be taxing the hydraulic capability of the WD45.
mattb ![]() Orange Level ![]() Joined: 11 Jan 2011 Points: 348 |
i use a d17 on a six row jd 7000 picks it up and handles it good i think a 45 would too.
I had my WD45 with dual hydraulics hooked to my 6RN 7000, it wasn't pretty and all I wanted to do was pick it up which it eventually did. OTOH my D17IV handled the planter with ease.
Roddo ![]() Orange Level ![]() Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
I use an IH 56 4 row plate planter. Its perfect since it has mechanical marker trips on chains. Ground drive so no PTO to muck with. I just took one hose off of the cylinder and vented it and it works great for me. They can be had cheap cheap too. Easy to work on and set up.
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
If you ad an auxiliary tank to the pump and a second output remote with a shutoff valve on each, (shut one valve off to use one marker, the other for the other marker) I could see your 45 handling a planter with hydro remotes.
German Shepherd dad
I by-passed the lift cylinders and used a small diameter cylinder and it almost picks it up to fast and its a series 1 tractor. I dont even have to downshift on the ends. Screwed a coupler where it goes to lift houseing so i can go back and forth between useing lift cylinders and not. Works better than i thought it would.
I mean lift arm cylinders.
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
I pull 6-30 JD 7000 with AC lift cylinder with WD45.Works well.Fliud or wts helpfull.
