Piston Rings
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: Piston Rings
    Posted: 03 Dec 2009 at 1:40pm
I am not sure if it was this board or YT but a few years back I was explaining how years ago when I would overhaul and engine I would buy over sized rings after measuring the cylinders. I was taken to task and someone posted that it was mis information. I did a search and could not find any thiing to back up my statment and let it drop.
I just purchased a coupla sets of old stock oversized piston rings. I thought some might like to see them.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 2:02pm
Dick, I don't remember the original post, but I too thought we used to be able to get oversize rings that would still fit the original piston. I seem to recall helping Dad overhaul more than one engine and that is what we would do. If I recal correctly, you could only bore the sleeves to.030 over. That has been a lot of years ago and not certain I'm correct about that though..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 2:17pm
A set of .060's sold last night but I didn't bid on them.  The only over sized rings I had installed were .010.
I have a ring file to fit the over sized rings to the cylinder diameter.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 3:13pm
This subject is new to me.  My question is.  What part of the ring is oversized?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 3:35pm
Dave H, The diameter and the depth. I just received my first purchase today, one set of standard 3.5 and one set of 3.5 .020 over sized . I will take some pictures to compair the standard to the over size rings.  Like I said a while back, in talking with a fellow that had over hauled his tractor and was getting oil out the breather, I ask him if he had checked the ring gap. His answer was, what is ging gap? He did not know that it was important to put the ring in the cylinder before it was placed on the piston to check and see the distance between the ends of the rings. (called ring gap)
The B, C, and CA calls for .007 ring gap. If you have 30 or more you will have blow by with brandy new rings. The wider the gp the more blow by. Some of the manuals will have a chart telling what the ring gap should be but the manual will not tell you when to check it. Some do. Some manuals assume you should know some of the details when you start. Make it tuff on a newbe.
Ring Gap 002
Ring Gap 001
Way To Wide
Edited by Dick L - 03 Dec 2009 at 3:36pm
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 3:53pm
Dick Thank you very much for posting on ring gap. I would imagine there are a few orange people who can use this information. Your posting is what I like about this site!! thanks again Don in Indiana
skipwetle NWIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwetle NWIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 4:08pm
I always check ring end gap when doing a rering job.  I dont check on new sleeves and pistons.  It been a long time since Ive seen oversized rings, but they are out there yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:06pm
When I'm not playing with orange tractors, I play with old small engines. Briggs & Stratton and Wisconsin were very good about supplying .002 and .005 oversize rings and pistons. It takes a while with a ridged hone, but a .002 and .005 can be done without paying a machine shop to do it.
Filing ring gaps and taking the time to get all clearances, etc perfect used to be called "blueprinting".
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:58pm
The old art of rebuilding a engine has bee nlost as now most things are remanufactured or done in a machine shop. Knurled pistons or shot peened , fitting pistons and rings to bore or even lapping valves. A lot of the old ideas are now replaced with the disposable mentality or it fits , it's overhauled.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:11pm
  the rebuilder is the quality control inspector now according to my machine shop
   the are having it happen all the time on new products   have been in business for 30 some yrs.  getting worse all the time  my 2 cents   we have had rod bearings in wrong packages  std in .020 boxes
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:31pm
What happens if the gap is too tight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:37pm
Dick, you talking about putting .030 over rings on a standard piston?  I have done that with .010 rings.  You got to watch  the clearance as you said. If you are suppose to have .005 bore clearance and you have .015 at the top and can hone it out to "about round" and have .015 oversize, that is .010 EXTRA bore, which i believe  is about the max. Since the circumference is 3.14 TIMES that much, your ring gap would go from .007 to .038  --- thats why i buy .010 or .020 oversize and file to get back to .007 --- thats what your saying, and still use the standard piston ??
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:52pm
Jordon If the ring gap is too tight when the engine warms up and the rings expand to the point that the butts touch the engine will sieze up, often times it will break aring. Cal in Ct.
Wendell(OK/TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell(OK/TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 11:47pm
Dick, guess I missed the original post as well.  Dad rebuilt a lot of engines when I was young and he was able to do it.  Make, model or color didn't matter, Long as we had the equipment to handle it, one guy brought the just the engine to us after we told him we didn't have the stuff get it out of his big oilfield wrecker!  Anyway, oversize rings were a common fix, especially for tractor and small engines.  I have a set of .010 over for a B and a set for a WD that I picked up off EBAY several years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 7:08am
As Norm stated, the rebuilder has to be the quality control.  Really it should always be that way for the rebuilders peace of mind. I have always checked ring gap on a new kit also. I found one pack of rings in a new box that would not square in the hole. It had an over lap rather than a gap. NAPA just replaced the one ring  pack for me. Had I put them on the piston and tried to drive the piston down I would haf broken a ring and damaged the piston.
Steve, Yes the over sized rings were made ot use on the standard piston. When checking ring gap I use a bare piston to keep the ring square and check  several places from the top to the bottom. Before deciding the amout of over size ring to buy you would need to hone to as close to the same diameter from top to bottom.
Time for PT, gotta go and will post pictures in a few days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 7:50am
Dick
This has been real interesting for me.  Right now I have the motor out of a D 15 II and it had a considerable ring groove so I know there is some "extra room" in there.  I have for as long as I remember checked the ring gap as you desciibe.
I am just trying to get the geometry correct in my mind on the oversize issue.
So as usual, I will hone some to get a surface on all of the bore.  Then measure the inside diameter top and bottom and in different points to find the amount of wear from standard in the bore.  After all the measurements are taken in one bore I will use the tightest one.  If the smllest diameter found (or should i use the average) is at least .010 over the standard bore then I can use the 10 over rings?
Reasoning is that if you would use a 10 over and set the ring gap but the bore was not 10 over then the ring woulld/may chafe and bind in the bottom of the ring groove on the piston.
When you get the time I would appreciate you expanding on what my thoughts are and if I do not quite understand the whole concept yet.
thanks - Dave
Barry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barry Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 7:54am
Boy you guys are great.  I am somewhat of a newbie at this engine overhaul stuff.  I've removed the head, pistons and sleeves from my C that has low compression.  The pistons look OK although one has some scuffing.  The sleeves are tapered .008.  I'm planning to put new sleeves and rings in.  Now I'll check the ring gap before I put the pistons back.
Going to remove the valves today.  At least they don't appear to be burried down in the seats.
