Piston Question |
TMiller/NC ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Jan 2020 at 3:21pm |
What is the significance of the "notch" in top of piston? ![]() |
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8543 |
Tim,
My guess is that it faced forward in the tractor?? Regards, Chris
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24766 |
Maybe points toward front of engine, an 'alignment' mark ?? Hay, it's been a very long while since I was in Grade 9 autoshop !! now, am I right ? Did I remember something good from highskool ??
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
What motor? Usually means that goes towards the front of motor. I remember there being a motor that the rods were clamped offset on the wrist pins and the notch was to make sure the right offset was in the right hole so the wrist pin didn't rub on the sleeve
It's a B engine with 3 7/16" liner and pistons............... I was so happy to get picture posted I forgot to tell engine size... Thanks, Tim
Some pistons have off set wrist pins for a different angel to crankshaft, so notch indicates front of engine. MACK
Thanks for the replies
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5092 |
Most notches indicate the oil drain holes in the ring grooves. The notches were not present in the original pistons and I personally have never given there position the slightest attention in this engine. In the slant 6 and the V8 engines I placed the notch or stamped arrow toward the outside.
