picker brackets
jhk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhk Quote  Post ReplyReply Direct Link To This Post Topic: picker brackets
    Posted: 15 Apr 2011 at 8:26am
I have two brackets that are mounted to the final drives and someone said they were for a corn picker, so if interested let me know as I have no use for them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 8:39am
Can you post pics of them or read any casting numbers off of them?  There were different brackets for different pickers.  Thanks.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 12:02pm
Does anyone have a picture of these in use? How does the implement mount or work with those brackets? My WD45 had one, I found a matching one at Dale's show last year.
1954 WD45 NF "Iron Tater"
jhk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhk Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 12:46pm
The guy that told me they were picker brackets said that you backed the tractor into these first. Thats all I know. Will try and get some casting numbers off of these this afternoon.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 5:05pm
if they are for 33, yes you back into them
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 7:13pm
  you back into all of them  have worn TOO MANY OUT  SAME BRACKETS WILL FIT ALL
jhk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhk Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 12:48pm
Number of the brackets are 536902 and 536901  and then there is a smaller number that has been stamped that reads T 12. Hope this helps you out. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 1:20pm
Those numbers are for a 170 picker to mount to a D17 or a 190 picker to mount to a D17 or WD45.  I am very interested in them if they are unbroken.  Send me a PM with what you want for them.
Norm - I am unfamiliar with the 33, 17, etc pickers.  But note that the brackets for a 150 picker to go on a D15 are NOT the same part numbers as these nor do they look the same size/shape (150 brackets are shorter) so I don't believe that the same brackets fit all tractors to all pickers.
Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
jhk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhk Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 1:56pm
I have no idea what they are worth what would you give for them, I want to be fair with you.  I need a pair of snap       couplers that go on the lift arms do you have any?
jhk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhk Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 1:58pm
me again my cell number is 641 590 6192
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 6:50pm
 the later brackets have some extra bracing but will still interchange lastone we had was a 170-190
