Picked up a 3 point adaptor n ended up with this |
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Aug 2024 at 9:06pm |
Going to make a GOOD parts tractor
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 538 |
Parts tractir??????
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Tractor
1984 80780
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3647 |
Nice. I passed on a 3pt adapter at consignment auction today. It was missing the chains, top link bracket, and middle braces
Edited by plummerscarin - 17 Aug 2024 at 10:49pm |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 802 |
What’s wrong with the d14 to part it out?
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5672 |
Nice haul Still got the Auction Tags hanging off them ! G |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 23651 |
hmm... 'needed' the tractor and plow to see HOW the adapter mounts ????
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2812 |
I see D 12 stickers on it. Nicest parts tractor I've ever seen. Thanks for sharing
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4858 |
Not a genuine Allis Chalmers 3pt adapter. Some companies aftermarket knock off.
OK, I have to know HOW did you decide it wasn't 'true orange' ?
True Allis Chalmers aficionados would see #1 it doesn't have a genuine removable AC snap coupler eye, #2 the lift links are generic shop made items, #3 generic top link mount, #4 looks to be CatII lower link balls, The genuine Allis Chalmers CA,D10/12 adapter will have CatI balls, #5 the cross bar would have a mount for the top link that would be used if it wasn't a PTO implement.
I bought this one because it will do what I want .
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2527 |
Cute little rascal!
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2244 |
This is a real A-C Cat. 1 3PH adaptor. The top link on this one attaches to the cross bar between the two main arms for use with non PTO equipment. The top link (beaming tube) on another model made for PTO equipment connects to a bracket on the tractor like any common 3PH. Fred's after market adaptor appears to be one of the better ones. ![]() A-C also made a Heavy Duty (category 2) adaptor which looks similar but is made of much heavier materials.
Edited by Brian G. NY - 18 Aug 2024 at 9:50am |
This is a real A-C top-link. Allis calls it a "beaming tube". Nice fancy hand wheel! And an original A-C top link bracket made to clamp on the rocker shaft on the WD and WD-45 tractors. ![]() |
I was getting some of those handwheels made however the degrading quality of the work the foundry was doing as each successive generation took over the business has made me decide I have what I need and it's not worth it to continue getting NLA parts made anymore. Now the great grandsons are running the business and they don't see the need to produce the quality that their great-grandfather was doing, they only have to do better than the Chinese. The handwheels I have will fit right onto a generic CatI toplink.
