picked this up
allis g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Topic: picked this up
    Posted: 03 Aug 2018 at 12:26pm
Got this yesterday not seized but don't know if it runs was stored inside for 20+ years old guy said it was on a lettuce harvester.  Missing the generator and cap for the gas tank and the muffler. It's got the distillate tank and gas tank on it.  How do I figure out what year it is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 12:33pm
here's another shot of it
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 12:42pm
oops
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 5:39pm
I think I can see some numbers stamped behind the air cleaner, in your pecs.  Look on the flange of the motor, area in question is sloped downward, at 45º, last inch of the motor casting, at the back end, left side, as viewed from operator's position, if it were a tractor.
Looks like a B power unit...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2018 at 5:45pm
Ok so I pressured washed all the gunk off of the unit.  Found an aluminum plate stamped with Allis Chalmers Power Unit Model B-125  Serial number as best as I can see it is
 PU-87246 followed by a B.  So if I just go by the numbers on that it is a 1947
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 7:57pm
Ok guys I found the serial number for the engine on the B125.  It is as best as I can tell
CE168259KA.  So if I read that correctly it was built in 1951 and the KA means it is a kerosene engine.  What does the CE mean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2018 at 8:43pm
I think CE means that it is a C Engine.  The only difference is in how the HP was rated, at a higher RPM, to give the C engine about 2 more HP. If yours is a distillate (kerosene) engine, its not much more HP, than a B engine, due to a lower compression ratio...
It is possible that an engine from a tractor was swapped into the power unit, at some time in the last 60+ years...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 12:41am
DIY  That's what I was able to find out too about the C engine.  Just needed to confirm it. So that means it was off a C tractor but also a kerosene tractor.   That is what was confusing me.  Still pretty cool though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 4:01am
“CE” at the beginning of the engine serial number, means it left the factory as a 125 CID engine.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2018 at 4:16am
Looks like CE 168259 KA would be an early 1952 as per Bryan Clemson website.
Gary
http://wsmth.people.clemson.edu/SNFind/esn_tsn1.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 10:23am
Ok thanks everyone now I've got to figure out what to do with it.  Thinking about a big fan on it like in the book.  It was a prototype,  thought that might be fun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis g Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2018 at 5:32pm
Ok here's another question. Look at the 3rd picture there is what looks like an electric oil pump next to the oil filter it has a wire running to the magneto and an oil tube out the bottom and another one out the side the bottom one goes to the bottom of the oil filter the one out the side goes back into the block? The top has what looks like an adjustment arrow on it.  Never seen one of these on any of my other tractors.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 11:12pm
That sounds like it may be a low oil pressure shut down switch similar to a Murphy switch used on irrigation engines.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
