perkins engine intake heater not getting power |
scootmas1972
Joined: 08 Feb 2018 Location: amarillo tx Points: 6 |
Topic: perkins engine intake heater not getting powerPosted: 08 Feb 2018 at 2:33pm |
i have a yale forklift with a perkins engine. i replaced the fuel injection pump and its pumping fuel just fine now. however i found that the injection pump is not getting any power. ive checked the fuses and they are good. if any one could help me i would appreciate it because i dont know.
scootmas1972
Posted: 08 Feb 2018 at 3:00pm |
ok. i ran a hot from the battery to the intake heater and rigged it to work but im still not getting it to start. fuel is flowing.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42263 |
Posted: 08 Feb 2018 at 9:39pm |
Give it a shot of either or WD40 into intake - (without the heater) and see if you get smoke or fire .
Perkins should start above 40 F without aids - unless real low compression - What color smoke are you getting when turning it over ? |
scootmas1972
Posted: 08 Feb 2018 at 10:38pm |
I have tried ether and wd-40 without the heater. So could there still be air trapped somewhere? I've bled it several times.
scootmas1972
Posted: 08 Feb 2018 at 10:39pm |
And im not getting any smoke
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35650 |
Posted: 09 Feb 2018 at 6:42am |
How do you know fuel is flowing? Lines loose, fuel at the nozzles?
When connect power does the pump audibly 'Click' as the solenoid kicks? No smoke is No Fuel. |
Coke-in-MN
Posted: 09 Feb 2018 at 10:12am |
On my perkins - when external fuel pump want bad - no fuel to injector pump - no smoke - so either the throttle shut off lever is in wrong position , or no fuel to injectors or pump.
It should fire off or try to run on either - when turning over loosen lines one at a time at injector to see if you have fuel pressure . Bleed each line or couple till it starts |
Morten.have
Posted: 09 Feb 2018 at 3:20pm |
If your completely sure that you got fuel, either diesel or start aid, and there is no smoke. Then check your valve lash...
Joined: 11 Sep 2009 Location: illinois Points: 90787 |
Posted: 09 Feb 2018 at 5:21pm |
I would guess you have fuel TO THE PUMP, but not OUT TO THE INJECTOR... either air trapped, or does it have a fuel shut off rod, or fuel shut off solenoid ??
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55265 |
Posted: 09 Feb 2018 at 6:29pm |
first things first... Model and serial number will help. Also pics of the injector pump, and fuel system will definitely help...
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34613 |
Posted: 09 Feb 2018 at 7:48pm |
Is the fuel pump in proper time? or off 180 degrees?
scootmas1972
Posted: 12 Feb 2018 at 2:57pm |
i have fuel going to fuel pump to injector lines to intake heater. when i turn it over i get a little bit of white smoke. it acts like it wants to start and then the battery gives out.
DMiller
Posted: 12 Feb 2018 at 4:08pm |
A little bit of white smoke is not enough fuel. May be in time and getting Some fuel but not enough to roll off.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 12 Feb 2018 at 6:17pm |
Too bad you can't pull it.That would get ya going.Try a rag and blowgun in fuel tank fill hole with lines broke loose.Dont seal it too much....
