Perkins 3.152 crankshaft (Allis 160 diesel)
Fellenz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fellenz Quote  Post ReplyReply Direct Link To This Post Topic: Perkins 3.152 crankshaft (Allis 160 diesel)
    Posted: 13 Jan 2012 at 2:15pm
Hello,
I need a crankshaft for one of our 160's.
I'm not having much (any) luck finding one new or refurbished with the spline nose. If anyone has a source for one I'd much appreciate it as I needed this crank ...yesterday!
Failing that does anyone know if the plain nose (keyed) crankshaft will bolt up okay? I'm thinking it may be possible to modify the pulley that drives the water pump and alternator to work on a keyed shaft if worse comes to worse and a direct drop-in crank can't be found.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2012 at 3:09pm
I'm no expert but when I searched 3.152 crankshafts on Ebay I came up with a few.  Als if they are splined or not.  I'm not sure if they are from reputable suppliers, but would be worth the look.  Good luck and let us know where you find one.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
H Clark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H Clark Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 7:51am
Fellenz
      I just had my crankshaft turned at Jim Minnicks in Charleston WV. They priced me a new one for $499.00 and said that it was the splined nose. Maybe you could give them a call. If you call ask for Butch their number is 1-304-776-2200. Hope that this helps.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
This page was generated in 0.052 seconds.
