Pat's vs standard quick hitch on 190 |
elmer
Topic: Pat's vs standard quick hitch on 190Posted: 22 Dec 2025 at 11:38am |
Sometimes I am a slow learner. After messing around many years I have the idea to make hooking up things a bit easier. I had been thinking of a standard 3pt quick hitch. I had forgotten about Pat's until I saw them on a search yesteday. Majority of the time I am putting out round bales. During winter I may use a rear blade when it snows or occasionaly brush cutter in late summer. Anyone have any opions or experience using one or the other? I may have to make a couple small modifications to use the standard quick tach, but not real concerned about that part. Thank you |
Randy WI
Joined: 22 Jan 2014 Location: Ogema, WI Points: 848 |
Posted: 22 Dec 2025 at 12:40pm |
I have a quick hitch on my JD 4066 compact and would not want any thing else also have the same set up on my JD 3032 very happy with that one to
Joined: 11 Sep 2009 Location: illinois Points: 89251 |
Posted: 22 Dec 2025 at 1:24pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54720 |
Posted: 22 Dec 2025 at 3:28pm |
Kinda re-inforces how far ahead of the game an AC snap coupler hookup is...
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2578 |
Posted: Yesterday at 5:29am |
I don't see a point to the Pats one. You still need to mess with the top link and it'll need adjusted out much farther to compensate for the Pats being set very far back. I'd just go standard 3 pt quick hitch and be done with it if you do anything. AaronSEIA
Posted: Yesterday at 5:35am |
That, and in some cases the PTO shaft gets stretched out more, which might also be a negative. Moving the implement 5 inches more to the rear could require more front end weights in some applications.
Edited by DrAllis - Yesterday at 5:39am |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24893 |
Posted: Yesterday at 7:02am |
I'm on the other 'orange' site a lot and there's always a lot of 'problems' with 'quick hitches' 1) Not all implements are QH compatible 2) QH isn't 'standard' a cat1 QH is TRACTOR side cat1, implement side is usually cat3 ! 3) adapters are needed, $$ per implement 4) PTOs need to be extended as QH is further from tractor 5) top link attachment isn't same, need longer top link My 'cure' was to have my 3PH implement bolted to SC-3PH adapters and dedicated toplink,also bolted on. This allowed me FAST hookup and no adjustments. I know won't work for all but made my life easy.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 664 |
Posted: Yesterday at 7:39am |
It doesnt seem like aftermarket inmplent manufacturers can read a tape measure because they have no consistancy in 3 point dimensions. I tried quick hitches but it would work on one thing and not the next. The smallest tractor i have is a D17 series 4 with 3point hitch. With extendable lower links its easier to just hook straight up because i was always having to take the quick hitch off
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5156 |
Posted: Yesterday at 8:43am |
kinda funny how he had to "wait" 2 weeks to do his job he planned, when he could have just taken the quick connectors back off and hooked it up like normal, and did his thing lol!
I have a rural king quick hitch on one of my 5020's and it works great for my driveway drag. I think the quick hitch is a little better since the top link is connected to it as well. You do have to put the special pins on your implement though. Edited by injpumpEd - Yesterday at 8:45am |
Posted: Yesterday at 9:35am |
Some of us are old enough to remember what some J.I. Case tractors had. They called it the "Eagle-Claw" hitch. You left balls on your implement lower pull pins and the draft arms were open on the top (like a quick-coupler) and had a latch to close and trap the ball once you backed in underneath and lifted the hitch to get connected. The downsides were the draft arms were solid side-to-side. No sway whatsoever. And I imagine the strength of those open draft arm ends were only good up to less than 100 HP.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5196 |
Posted: 16 hours 28 minutes ago at 7:22pm |
Oliver also had the same type of jaws on the lower arms as the "EagleClaw" and the balls were left in place on the implement.
in the later 50s many manufactures became aware of how much of a PIA hitching to larger 3PT equipment was becoming and most all devised some function to make hitching somewhat easier before the "quick hitch" came into being. Still nothing can be as easy as the SnapCoupler or FastHitch systems. The SnapCoupler has the advantage in that ALL adjustments stay with the implement and each is adjusted just as it was unhitched ready to work exactly as it did the last time it was used. The reason so may hitch attachments on the market don't match is something got miscalculated when switching MM to Inch measurement in countries that use kanjis for writing their words.
elmer
Posted: 15 hours 26 minutes ago at 8:24pm |
Thanks guys. I think if I get anything done it will be the standard 3pt quick hitch. I had seen the Pat's stuff years ago, but had forgotten about it until it popped up the other night. I don't have the need to change things often , but getting a bit older and it seems that things just don;t seem to line up when I need to so I;m lifting , pusjhing or yanking something to get it done. If I do get something on I will have to spend a little time getting implements all in order. Thank you
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1184 |
Posted: 13 hours 2 minutes ago at 10:48pm |
The factory Allis 3 point adapter could be left on the implement..
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8759 |
Posted: 5 hours 43 minutes ago at 6:07am |
The extendable lower links on the lift arms of my factory allis 3 point hitches seem to make hooking up pretty easy for me.
Darrel |
Posted: 5 hours 29 minutes ago at 6:21am |
For sure. And the fact that you can (if you remember how) raise and lower the draft arms while standing at the rear of the tractor with the engine left running, to fine tune your hook-up. The mighty One-Ninety was the first to have that feature. Series 4's and 170 thru 185 you could reach the Position Control lever easily from the rear. One just had to remember to leave the Lift/Lower hitch lever in the T.Boost position.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4198 |
Posted: 4 hours 47 minutes ago at 7:03am |
I have a quick-hitch that was on my 1066 when I bought it, think there is another one in a shed too. Haven't found an implement that it will hook to yet, Top-link is always wrong so it just sits and takes up space. One would probably work fine for semi-mount plows, which I have several of, just not nesaceary. I have a pair of fast-hitch adaptors that work great! Also have a factory IH quick-hitch that might be good but haven't tried it yet. It's also for fast-hitch tractors.
