OT Cub Cadet 1811 |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: OT Cub Cadet 1811Posted: 23 Mar 2016 at 5:35am |
I have a 1989 Cub 1811 with the twin Kohler 18hp motor.
Last year it started not charging, actually showing a discharge when run at operating RPM. I've checked my connections, anything else obvious that I am overlooking?
Charlie
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 23 Mar 2016 at 8:57am |
is it a kt or a magnum ?
Charlie175
Posted: 23 Mar 2016 at 9:12am |
M18
I do have a service manual, I need to dig it out.
Charlie
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 23 Mar 2016 at 12:01pm |
A lot of common problems I've found with the twin Kohlers and Commands, is a broken stator wire from vibration, stator failure, or VR issue. Another problem I've found was bad grounds.. HTH
Steve@B&B |
HudCo
Posted: 25 Mar 2016 at 9:33am |
took awhile to get back what steve said, and also check the key switch connections to make sure power is making it back to the battery. magnun should not draw of the battery after it has been started unless it has a afterfire solniod. out side wires on voltage reg are a c from stator middle wire on reg will be d c to battery did not look up spec but you should have prob 25 to 30 vac to reg at high idle and at least 13.8 vdc out
