Open Freeze Plug FIlls Engine w/ Water
keysas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keysas Quote  Post ReplyReply Direct Link To This Post Topic: Open Freeze Plug FIlls Engine w/ Water
    Posted: 03 Apr 2010 at 11:29pm
I really blew it today!  I've been working to tune up a 1951 Allis Chalmers B in hopes of selling it soon.  Its last start was about 5 months ago so I charged the battery, added gas, opened the fuel valve, and turned the key.  Success!  After running for about five minutes, I checked the radiator and saw it was low on water.  I got the hose and started filling.  The engine started running rough and then shut down.  Before starting it again, I wanted to fill the radiator, so I kept filling.  Suddenly, I realized water was dripping from EVERYWHERE around the engine block!!!  My post-flooding investigation revealed that one of the engine head freeze plugs under the valve rocker arm had completely popped out, allowing water to flood under the valve cover and flow down into the oil sump.  I'm guessing that water also got into the cylinders that had a valve open.
I'm writing to the forums to see if anyone else has ever had to deal with this and what was required to fix it.  At the least, its replace the oil, head gasket, and dry out the cylinders.  At the most its an engine rebuild.  Comments???
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 1:03am
The more common problem with those freeze plugs is that they rust through and put water into the crankcase. There's not a connection to the cylinders from the top of the head except around the valve stems so maybe you didn't bend rods, but you certainly didn't help the lubrication of the rod and main bearings on the crankshaft, or the bearings and cam followers on the cam shaft. So you may find bearing inserts welded to the shafts. Pistons lubricated by splashing water probably got scuffed too.
Gerald J.
maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maurice Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 6:24am
Forgive me for being a bit off-topic; does a WD have similar freeze-plugs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:03am
Most likely what stalled the engine is just having so much oil/water in the crankcase. I saw a lube tech at the dealer I work for do that once. He forgot to drain the old oil and pumped in the new. The engine would hardly run because of being so overfull, the crank/rods were submerged. I'd put a new plug back in it, flush the crankcase thoroughly with new oil, get it up to 180 degrees and run it to evaporate any remaining moisture.
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:14am
We get water in our boat engines all the time, have been very successful by changing the oil several times. Just replace the plug and get to changing the oil. Don't know why you would need to replace the head gasket.  If it was sitting there idling with no load as you were filling the radiator I doubt there is any damage caused by the water.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:17am
Drain everything dry, put in (new) freeze (plugs), fill up with oil and water and everything should be fine.
It is not like you used it for an extended time that way.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:19am
Maurice, yes the WD does have freeze plugs, most engines have them.
I would do what Brian said but also before starting it I would pull the spark plugs and crank it over so if there is water in the cylinders it will blow out.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:20am
Most all heads will have freeze plugs. (proper name is core plugs) It is how the sand is removed that forms the water passages inside the castings.
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 9:50am
Dick L, haven't hear that term in a while. I worked 16 yrs in an engine foundry. That is pretty much the reason for those silly holes, have to get the sand cores out of there some how. Siamese in the water jacket or between the bores would be an issue without core plugs.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 8:51pm
Drain everything that you can. take the plugs out and turn the engine to be sure there isn't any water in there, shouldn't be. squirt some oil into the cylinders, Get fresh oil in the crank, change the oil filter. Make the repair and got it running AS SOON AS YOU CAN. GET IT HOT TO DRY IT OUT. If you wait, the rust will begin. When ever a boat sunk, we would get it up and start it asap. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote keysas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 8:05pm
Good news - the tractor still runs!  I followed everyone's advice: tapped the freeze plug back into the head, drained the gallons of water and oil from the sump, replaced it with 4 quarts of used auto oil, removed the plugs, added oil to each cylinder, drove the engine with the starter for 10 seconds or so, reinstalled the plugs, filled the radiator, and squirted some starter fluid in the air intake for good measure. Set the key, pulled the choke and starter, and off she went!  Ran for about 15 minutes to get it good and hot.  Then closed shop because it was getting dark.
Next time, drain the auto oil and add back fresh stuff.  Thanks for all the help everyone!!!
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 9:34pm
Should have drained it while it was hot. Every oil change.
Gerald J.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 5:29am
That's good news. Glad it is working out for you. God Bless.
gdtractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 10:46am
Hi ..  you don't have a pic of the freeze plugs on an allis B or C engine do you?   thanks much ..
freeze plugs on the head of an allis chalmers c engine
thanks Gary
gdtractor
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:17am
Edited by Dick L - 24 May 2017 at 11:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:53pm
gdtractor, the frost plugs are the yellow holes in top photo, shiny silver in the bottom photo.
Just tear into em (yes, wreck em) to get the old ones out (ALL 3 of them)!!!
Gently tap the new ones to get them started then use something that will cover the entire top and tap them in with a hammer so they are flush.  The indentation is toward the top.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 6:48am
Now that you got it running, I think I'd go ahead and replace those freeze plugs as if one popped out, the other's eventually will. replace them with new, per the shop manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 4:42pm
 what exactly is a "wet sleeve" what is it referring to ? water or oil? and what is the purpose?
(unfortunately I am in St Louis - actually St Charles .. MO .. for a wedding so i can't work on it)
Thanks much
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 4:44pm
 just what is a "wet sleeve" what is it referring to ? water or oil? and what is the purpose?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 4:53pm
A engine is either straight cast iron with bore being part of the block - that is machined to size for pistons to run on the cast iron forming the full block casting .
 Wet sleeve engine has block casting machined so a sleeve (liner) forms the bore for the piston to run in . These are a separate casting or steel sleeve that is fit to block - generally sealed top and bottom by head gasket and o- rings on bottom .
 Now this sleeve can be cooled by water surrounding sleeve or in some cases the sleeve is dry and no water touches it but contact with cast iron block is used for heat transfer
 Now in some engines the pistons are cooled by oil spray from rod onto piston and sleeve bore .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 5:50pm
4 cylinder motor with wet sleeves removed.  What you see inside is the water jacket open to the backside of each sleeve.
DenGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DenGuy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 7:30pm
I'm hoping this is my trouble as well. I40 with double full crankcase. Coolant mixed with oil. Ran well on start up and I had just purchased it and parked it. I don't think I had more than 20 minutes or so run time on it when I discovered the problem. New oil and coolant at purchase. Makes me suspicious... hmmm. Drained the oil pan and now I'm waiting for a break in weather to pull the valve cover and pan for inspection. Be nice put new casting plugs in and get some work done. Smile Thanks for pics of the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 8:22pm
Where are the freeze plugs on a B or C Allis engine?   Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 9:06pm
Scroll up about 9 posts, fer the picture...Wink
Edited by DiyDave - 30 Nov 2018 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 9:08pm
Thx much ..  sorry ..  I didn't read the entire thread ..   :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote gdtractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 9:18pm
Thank you ....   are you saying ..  even though they LOOK good ...  they may or aren't ?
thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 10:22am
thanks again
You should have started your own thread on this, but since we're here right now.....
As long as you have the valve cover off and are in there, they are a cheap insurance plan to change them.  They can and DO rot out from the bottom side and you can't see this until it is too late.  It's better to change them out and then you'll know they are new.
Hope this helps you out Gary.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 10:40am
Like Ted said take a plug to a parts store and get new ones. Pretty cheap.
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 5:04am
What is the size ot the freeze plug for a C?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 7:51am
Hello John426,
Just a suggestion, it might be well to start your on post for such rather than tag on to one almost 10 years old. Review the info in past posts then start your own.
Core plug is the same for the B and C by the parts book, AGCO # 70203093.
The following dimensions were recently found for a member having a core plug leaking in a B head. HTH
# 70203093: 1-1/4" core plug = 1.13" ID, 1.26" OD, .33" deep (info I found on line) 1.260" is a standard OD for 1-1/4" cup plugs.
