One Sixty injector pump ?? |
AcFordHawk ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Boone, IA Points: 228 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Sep 2010 at 8:06pm |
Working through various items on the One Sixty I bought and finally got a chance to start it this weekend. Found a leak in the fuel system and appears to be coming from the gasket under the control cover on the injector pump. Thought at first it might be an injector line. I don't see obvious bolts or screws but looks like a couple fasteners could be holding it on. Is there external cover screws or are they internal and requiring the pump to be taken off and disassembled? Thanks for any help or advice. |
kip in cny ![]() Orange Level ![]() Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Is it a CAV pump ? a photo would help on this one |
160 CA 920diesel 5020 HD-3
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4959 |
that is a CAV DPA pump. The top cover is held down by 2 acorn nuts on the top, between the throttle and shutoff levers. Those can be a pain in the rear to get sealed up. If you take it off, be sure to look at the position of the governor spring on the throttle lever as well as the governor lever. good luck.
Thanks for the info. I'll get a picture or two tomorrow after work and post, first diesel tractor I've dealt with and want to make sure I don't mess up timing, pump, etc.
Here is a pic of the pump. End cap does say Lucas CAV on it.
It looks to have been rebuilt within the last few years based on the DELPHI tag.
