old ac tractors year of production
Brad from ks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad from ks Quote  Post ReplyReply Direct Link To This Post Topic: old ac tractors year of production
    Posted: 17 Nov 2010 at 12:02am
I just bought an old  chalmers tractor with a sicle mower infact it has two of them one is a 6 ft & the other is an older 4 ft with a wooden end the marking on the mag sez WICO Model XB I think & the spec is B 4000 or 4004 & the serial no is 044375 what year is it??
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 5:47am
Brad,  You may want to give us more information.  If it is a wide front, one row, tractor it would be a B 1940.  Remember, on a B,  the serial number is located above the gear shift lever.  Also, the B is a three speed tractor with a wide front and relatively narrow rear.  The mower is a box type frame that mounts on the tractor with the blade to the right in front of the rear wheel.  A four foot sickle bar would be a custom cut sickle bar since the B came with the possibility of 5' or 6'.  On some rare occasions a 7' sickle bar would be attached.  Does it have a starter and lightsIf you can attach pictures it would be a great help.
Let us know.
Good Luck!
Bill long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad from ks Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 6:09am
I was going by the info on the magneto, I'll check out the gearshift asap. Yes it has a 6 volt battery & a key & a guage of some type not sure yet. It has one  headlite on the rightside of the tractor, & i'll also be looking for the serial no by the gear shift. Thanks alot It looks like it's in excellent condition &  the mower on it now is the 6 ft one & in excellent condition as well. The older 4 ft mower is outside but in fairly good shape, the wood on the end of the mower is "kinda" needing replaced lol but all the iron is there & the guards look like new, not one dent, or buckle anywhere. all in all it's a damn nice little tractor, it's always been shed'ed & ran at least an hr or two every year
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad from ks Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2010 at 6:13am
it's a wide front too
