OK last post about hyd pump |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2559 |
![]() ![]() ![]() ![]() ![]() Posted: 19 Mar 2011 at 4:45pm |
on the 19. I had put it back together and was compressing the big spring with the pump in a vise when something hit me on my foot. It was the pin that holds the rollers onto the assembly. I then took off the 4 follower assemblies and tig welded the pins so they can't come out now. Once a pin comes out and the roller falls off all heck breaks loose!
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
So what are you going to do about the lobes that were destroyed? Bob
Dean(IA) ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: NE Iowa Points: 430 |
You may want to flatten 2 8 P galvanized nails and then hold down two
cam followers and insert the nail to hold 2 down with one nail. Let the heads of the nails go out past the edge of the mounting pad so that after you get the pump installed and the nuts just started, you can pull the nails out. I hope this description is clear enough to follow. HTH |
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Dean, your method works with a WD/WD45 pump, but this is the belly pump on a D19.
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Recon Dana got in there with an angle grinder and "trued" em up?
I did grinf, file and sanded but I am still not sure what we are going to do. Thanks, Dana
