Oil pan Gasket video |
Page <123> |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 21 Aug 2014 at 2:11pm |
Well Jim I might do a video on WD/WD45/D17 brake pins sometime down the road, Most of the guys on here will not like the way I change brakes, I cut the pins off first thing and don't fight them danged old pins at $15.00 per pin it's to much trouble to save them for me. lol |
1946WP
Posted: 10 Sep 2014 at 10:07pm |
great video, thanks.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 11 Sep 2014 at 4:15pm |
Thanks to EVERYONE involved in the making of this film!! GREAT job by all concerned. Don, accolades to you for knuckling under and becoming a movie star now. Hats off to you!
For you guys on iPhones, here is a converter place to make this better for your phones and also to you guy on PCs that want to save this for the future. http://www.clipconverter.cc/ I saved it in AVI and also MOV for future use. ** BE VERY CAREFUL,,,,,when you go to download the video, another window will open with some jibberish in it. DO NOT click on ANYTHING in this window except the X in the corner to SHUT THIS WINDOW!! ** I like the idea of doing a brake job on a WD/WD45. And I agree with you Don on just cutting the pins out! Saves a lot of time and grief! Congrats!! You are right up there with Tom Mix now. LOL Edited by Ted J - 17 Nov 2017 at 4:05am |
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 11 Sep 2014 at 7:24pm |
that's the way I do it to don,i give them one chance and then it is the Hobart plasma torch.....
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 23 Oct 2014 at 7:15am |
I've tried watching this on my phone and computer and the sound is muffled and garbled.. anyone else have that problem?
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
Don(MO)
Posted: 05 Nov 2014 at 7:52am |
I just looked at it and the video is working fine for me.
dashingrampallian
Posted: 10 Nov 2014 at 2:46am |
Nice video... :)
Don(MO)
Posted: 10 Nov 2014 at 8:54am |
I'm going to get a diff head for my plasma torch that will let me get up inside that little hole better. lol |
B26240
Posted: 06 Jan 2015 at 6:50pm |
Don you did a great job!!! Thanks to all involved with this effort. Mark
Don(MO)
Posted: 07 Feb 2015 at 9:06pm |
OK guys after a phone call I got asking about the oil pan INFO, I just went back to watch the video again and low and behold I made a big mistake on the oil pan's with I said in the video it was 4 3/4" that's wrong, it is 4 7/8"
I'm sorry for the wrong INFO in the video, Please add this note to your list. |
beanking
Joined: 09 Feb 2015 Location: Indianapolis Points: 7 |
Posted: 09 Feb 2015 at 12:59pm |
With background noisebut understand what his talking loud and clear.
David Terry
Joined: 15 Feb 2015 Location: Lawrenceburg TN Points: 41 |
Posted: 01 Mar 2015 at 6:10am |
Great Video. I am in the process of upgrading my WAC and I for sure don't want any oil leaks. I've got an Oliver 880 with a pretty good oil leak in the rear, and I'm going to pull it and see where I went wrong the first time I "fixed it". Thanks again for making the video. Dave
alliskid13
Posted: 18 Mar 2015 at 9:08pm |
Thank you to everyone who was involved in the video. I am rebuilding my 57 WD45 and needed a few tips on putting the seals on my oil pan.
JM
Joined: 12 Sep 2009 Location: United States Points: 379 |
Posted: 14 May 2015 at 9:12pm |
Great video, wish I had seen it before I did mine. I have one question, can the rear seal be replaced in the tractor? Would you have to loosen the mains to let the crank drop a little?
CTuckerNWIL
Posted: 14 May 2015 at 9:19pm |
You wouldn't have to loosen the crank, just the remove the rear cap and remove the top retainer. The clutch and flywheel have to be removed to do this.
allishawk
Posted: 30 May 2015 at 5:59am |
Great video Don. What should a guy use for gasket material when making the "F" gasket for the early motors?
Don(MO)
Posted: 30 May 2015 at 1:01pm |
I make .012" to .015" thick gaskets. Hope this helps. |
BillyTheKid
Joined: 08 Jun 2015 Location: Upper Michigan Points: 4 |
Posted: 09 Jun 2015 at 11:44am |
Great video. Should be titled A Hundred Ways for Your New Oil Pan Gasket To Leak.
MARK W (NY)
Joined: 14 Sep 2009 Location: E.Concord NY Points: 279 |
Posted: 18 Jun 2015 at 9:40pm |
When talking about the F gaskets You said the early models, ,where does a 1950 WD fall into the mix Early or late ? Thanks
Its a Great Life if you don't weaken
Don(MO)
Posted: 19 Jun 2015 at 5:46am |
Mark, your WD will use the little F gaskets, If you go back and watch the video again I show how to tell the difference in the F gaskets needed. Hope this helps. Don |
79fordblake
Joined: 01 Jul 2010 Location: West Kentucky Points: 829 |
Posted: 20 Dec 2016 at 5:53pm |
Geez I hate to even ask this question because I watched the video and I know what it said. But anyway here I go...lol. I had my WD45 block aligned bored so there will be no shims. I ordered the correct NOS "F" gaskets from my Agco dealer. Will they cause an issue using them or do I need to do something else?
CTuckerNWIL
Posted: 21 Dec 2016 at 11:57am |
Line boring shouldn't make any difference. That only removes the shims from the Main Bearing and has nothing to do with the rear seal.
79fordblake
Posted: 21 Dec 2016 at 12:21pm |
So the "F" gaskets won't hold the main cap up giving more clearance?
Don(MO)
Posted: 21 Dec 2016 at 5:04pm |
Hey Blake, please go back and look at the video again at 9:50 to 10:00 I talk about F gaskets and line boring. I talked about the F gaskets in the 170 that don't have shims and still use the F gaskets. If you need more INFO PM me and we can go over more.I'd be happy to help.
srvpks
Posted: 29 Jul 2018 at 6:06pm |
Thanks for making & posting this video, it's very helpful. I might have missed it in the video but do you apply gasket sealer to the "F" gaskets?
Don(MO)
Posted: 29 Jul 2018 at 11:07pm |
No sealer on the F gaskets, just clean and dry.
srvpks
Posted: 30 Jul 2018 at 7:16pm |
Thanks Don!
New Old Owner
Posted: 23 Nov 2019 at 2:20pm |
I recently found Don's video when I discovered my front seal leaking. I've had the WD for 1.5 yrs and the PO said he paid to have the rear seal replaced. To replace the front seal do I also need to replace the rear seal? I plan to order parts from Steiner and want to make sure I have everything needed. I don't have an indoor shop so will be replacing it in the elements. Any help/advice appreciated.
CTuckerNWIL
Posted: 23 Nov 2019 at 8:27pm |
No, all you really need to do is pull the radiator out of the way and get the front pulley off. The seal can be removed by using a self tapping screw and prying it out.
I would advice you check concentricity, between the bore and the crankshaft before installing a new seal. The front cover is not doweled in place, so there is no guarantee it is line up properly, since it can 'float' in the bolt holes. There are several ways you can do this. A magnetic base with a dial indicator, mounted on the crankshaft would be great, but most guys don't have these things in their toolbox. I know people have turned a short plug so the OD is .002 smaller than the seal bore, then bore the middle out to .002 over the crankshaft diameter, and us it a s a gage or alignment tool. Edited by CTuckerNWIL - 23 Nov 2019 at 8:28pm |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8645 |
Posted: 23 Nov 2019 at 9:10pm |
New Old Owner, First: Welcome to the forum! I would ask how bad it the front seal leaking? Sometimes the pain is not worth the gain?? If the PO paid to have the rear seal done, and its not leaking then someone did a good job on it! I have done a couple of these in different ways. It has gererally been improved when I am done but I would call it a controlled leak after the repairs! Just my 2 cents:) CTucker has excellent suggestions for the tool to align the crank and housing. And no you dont have to do the rear seal when replacing the front one. Realize that to do this front seal you may or may not need to have the timing cover loose to move it into alignment with the crank! That could mean more tear down and more room needed to work. If you take the timing cover off you will need the timing cover gasket also. Then I think about the pan gasket corners which are under the timing cover lower corners. Humm. If I were you, I would call and see if Don(MO) would take the time to walk you through the front seal replacement process too. He is very good on these old WD's! It would be well worth your time! He convinced me that the rear seal work needs to have the engine removed to do it right! Regards, Chris
Page <123> |
