Oil Level???
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: Oil Level???
    Posted: 25 Feb 2013 at 2:46pm
  On my WD puller, I have reworked the hand clutch. What is the minimum oil level once the pto and hyd. pump is removed? Does it still need to be to the "FULL" level?
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 7:05am
If you have removed all the gears, it needs to be up about 2" on clutch. Best thing would be to remove clutch and use sealed bearings and run no oil.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 7:20am
  This tractor was bought as a "puller". I changed all the oils over the winter. Every compartment was full of what looked to be 140wt gear oil/water. I put hyd oil back in the hdy section, and also in the hand clutch section. Filled the differential and final drives with 80/90. Everything is to the full level, could I loose a significant amount of weight by lowering the oil levels with damaging anything?
