oil in a 1983 5030 allis 2 cyl diesel |
Thomas-NC
Joined: 10 Jan 2011 Location: Pikeville, NC Points: 25 |
Topic: oil in a 1983 5030 allis 2 cyl dieselPosted: 24 May 2019 at 3:06pm |
Manual calls for straight 30 wt and says not to use multi grade oil. Will 15-40 Rotella work
Edited by Thomas-NC - 24 May 2019 at 3:36pm |
Joined: 11 Sep 2009 Location: illinois Points: 90834 |
Posted: 24 May 2019 at 3:55pm |
I can't imagine how an engine would know it had multi weight oil in it.......... 15-40 is an EXCELLENT diesel motor oil. 15 will get easy starts and fast oil pressure buildup in the winter, and 40wt is a good oil for southern US states in summer.
Edited by steve(ill) - 24 May 2019 at 3:57pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55290 |
Posted: 24 May 2019 at 5:57pm |
Don't forget to drain and replace the oil, in the injector pump, occasionally! IIRR, it has its own oil reservoir, with its own oil plug...
EricPA
Joined: 13 Sep 2009 Location: Watsontown,PA. Points: 2578 |
Posted: 25 May 2019 at 3:12pm |
15-40 is all I've used in my 5020 in the last 10 years
Life is tough,but it's tougher when you're stupid. - John Wayne
Thomas-NC
Posted: 28 May 2019 at 6:57am |
Thanks for the help and tips. Much appreciated!!
ChrisS
Joined: 10 Mar 2016 Location: St Marks, KS Points: 65 |
Thanks(1)
Posted: 10 Jun 2019 at 1:09pm |
I guess if Eric hasn't had any issues in 10 years than the injection pump doesn't care about using a multi-weight oil either. I have been trying to change all my diesel engines over to Rotella 15w-40 and just have one oil on the place.Chris
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 10 Jun 2019 at 2:12pm |
the pump won't care! put 15W40 in it, it'll be just fine.
