Off color question about Vermeer 554 XL Baler
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: Off color question about Vermeer 554 XL Baler
    Posted: 28 Aug 2016 at 9:38pm
Just wondered if any of you guys had one and what you thought about them , the baler Im looking at has a monitor and accu tie ??? what all will monitor do and what is the accu tie . I just sold my 504 super G that was electric tie with toggle box so this is whole new set up to me . Thanks for any advise and help with baler, guy that is selling it just got on trade for a bigger baler and says it in good shape and ready for field but of course he's never baled with it . Thanks for any in put
Adam in VA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam in VA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:01pm
I don't have a 554XL, but I work in sales at a Vermeer dealer. If it actually has the monitor with screen then it's probably an "Accu-Tie Plus" monitor. Technically the "Accu-Tie" was just an auto-tie control box without a screen. If it has the screen then it should show several different things. In the upper left hand corner is the bale size/target bale size indicator. Before the bale hits 36 inches it will read "--/60" or whatever you set the target bale size to. Once it hits 36" it will begin to read the size and change as the bale grows for example "39/60","40/60",41/60" etc. Once the bale gets within 6" of target size then you get an "early warning" alarm from the monitor so you can be sure to finish the bale off well. Once it hits the target bale size you'll get a second alarm that tells you it's time to stop and let the bale tie. Screen also shows "Tailgate Open/Closed", "Net or Twine", and it it has "Bale Shape Indication" on the baler then it will show how the bale is forming on the right and left. The monitor will also display a "field" count if you bother to reset the count between fields/years etc. and also displays a total lifetime count. The buttons around the screen allow you to change the settings for twine wraps, start wraps, end wraps, center wraps, etc. Adjust amount of net wraps (3, 3.5, 4 etc). Pretty much all settings are easy to get to and adjust. I will attach a picture of the "Accu-Bale" monitor that should be pretty similar to the "Accu-Tie Plus" monitor that a 554XL baler should have. All in all the XL balers were pretty good. If someone took care of it and you have a decent Vermeer dealer around then I wouldn't be afraid of it. Hopefully this helps you out.
D21,D19,(2)D17,190XT,ED40, WD45,WC,B,25-40(Thresherman's Special),5030 plus buildings full of other stuff
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2016 at 9:07pm
It is a pretty automatic system for sure. just stop forward motion when the second alarm sounds and it puts the twine or wrap on. I like mine.
