Off Color John Deere B question |
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2077 |
Topic: Off Color John Deere B questionPosted: 05 Jan 2011 at 3:17pm |
What weight gear oil is used in the rear end and how full do you fill it/where is it filled? Also, where is the fill hole for engine oil and what weight it that? Grandpa always knew about the Deere, I just know the basic stuff. I had all this stuff written down, just can't remember where I put the paper.
German Shepherd dad
pumpkin man
Posted: 05 Jan 2011 at 9:23pm |
Trans & Rear End use Gear OIL 80/90 will work Fine Cap, 4/41/2 Gals. Motor oil filler is on the right side top of motor by belt pulley its a pipe cap use motor oil[your choice] oil level check valve is on right side below belt pulley oil filter is on bottom of engn. Cap.6/8 qts. dont forget 1st. reduction gear thats the pipe plug behind the oil pipe drain plug is behind belt pulley Cap. about 1/2 qt. use motor oil. |
pumpkin man
Posted: 05 Jan 2011 at 9:32pm |
Trans Rear End filler plug is on the back right by P T O no dip stick if it runs out its full if it dosent put some in. |
