off color jd 240 kawasaki oil leak
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: off color jd 240 kawasaki oil leak
    Posted: 24 Mar 2014 at 6:05pm
I have a jd 240 mower with a Kawasaki engine. it has developed an oil leak behind the starter. I believe it is the case halve seam. does anyone know how there are sealed? is it a gasket or sealer? I am hoping this could be repaired without doing much more than pulling the engine and turning it upside down, unbolting and resealing. if there is much more to it than that i'll probably do a full rebuild. any info would be greatly helpfull
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2014 at 7:59pm
I believe its just a gasket.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 8:36am
Yes they have a gkt. You  might try tighting all the case bolts.. Hasn't been a problem that I know of. You can go to Kawasaki web site and look at parts manuals for it.
