Off color David Bradley
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: Off color David Bradley
    Posted: 04 May 2014 at 8:47pm
Iv got an old David Bradley walk behind that I'm tired if fighting with the old B/s engine. I thinking of repowering it with harbor freight engine. So this is two part question how good are the harbor freight engines one , and two dose anyone know what the wright size pulley for one of those I think mine a four inch and if i don't just idle the engine you have to run with it. Thanks
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2014 at 8:53pm
I used a harbor freight engine on my last David Bradley and I would definitely recommend it. It won't look original and won't work with a hood if you have one, but its reliable and easy to stop. I had a 2 inch pulley on mine and it was a decent pace, not too slow not too fast. The 6 hp is all you need and it has a 1 inch spindle for the pulley. Hope this helps!
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2014 at 9:19pm
Thanks mine don't have a hood so that no problem. I kinda peaces mine togather
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 4:53pm
would you put a chinese engine in your allis
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 6:16pm
What is the problem with the engine you have? What is the model # of the tractor? Should be an I.D plate on the side of the transmission gearbox.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 8:06pm
It the second searis they made but it doesn't have the original engine anyway. Like I said I peaced it togather out of stuff I just found around. It has a briges 5 hp it will run good then flood and then start missing and you'll have to pull the choke to keep it running. Iv done all I know to do iv sanded the flywheel reset the gap on the coil new plug cleaned the gas tank and carb. Replaced the rubber diaphragm in the carb and air filter. I'm just tired of working on it spending money on it and having the same problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 8:39pm
s1166.photobucket.com/user/wdtractorman1984/media/Mobile%20Uploads/image_zpsb97764ea.jpg.html][/URL]
http://s1166.photobucket.com/user/wdtractorman1984/media/Mobile%20Uploads/image_zpsdf0ab244.jpg.html][/URL]
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 8:58pm
Check the gasket between the carb and the block. I've had them suck air in on water pumps with these engines. Makes it run crappy.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 11:55am
these tractors had a 1-1\2 bs motor on them. you dont need that big motor you cant hold it back with the little one. an thay sure plow nice'
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 8:19pm
I think I'm going to try the gasket between carb and engine block on the ol gal. And I'd like to have plow cultivators and few things for it all iv got is a disc and home made trailer. Wouldn't have the disc but found it at the scrap yard in crush pile
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 9:36am
sererate the carb and tank it has two pick up tubes and a jet in there and they probley pluged it is always easy to check the valve lash while the carb and tank is off
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 5:52pm
I ended up with a new B & S 6.5 on mine,---used a 2" pulley, runs too fast but cant figure how to slow it down,--and yes the original engine was a 1-1/2 hp, either a pancake or vertical style engine! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 12:07pm
the smaller pulley you put on the motor the slower it will go. around a 1-1\2 pulley was on them with place for two belts
This page was generated in 0.270 seconds.
