NOS new idea mower part fs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: NOS new idea mower part fs
    Posted: 04 Mar 2025 at 3:29pm
Hello
Have some nos new idea mower parts for sale.
Some might fit more then what iv lister.
028-HS wear plate fits 10,10A,20,30,40,40H,41,250,253,254
037-HS wear plate fits 10,10A,20
0118-HS pitman head plate fits 10,10A,20,30,40,41,250,253,254
0119-HS pitman bar reinforcement strap fits 10,10A,20,30,40,41,250
0127-HS cam pitman fits 10,10A,20,30,40,41
Also the little wrench 0129-HS,0130-HS pipe
081-HS pitman strap, plain front. Fits 10,10A,20,30
080-HS pitman strap rear, fingered fits 10,10A,20,30,40,41
130-HS upper front wear plate fits 30A,30AH,30BH,40H,41
167-HS gag bell crank fits 30,30A,30AH,254
029-HS shim lower rear wear plate fits 10,10A,20,30,40,41,250,253,254
0673-HS upper front wear plate fit 30A,30B,30BH,40,41,250,253,254
0103-HS spring fits pawl ratchet hub 10,10A,20
0144-HS ledger plate fits 10,20,30,40,41,250,253,254
-0573-HS backstop bracket. Fits 30A,30B,254
-0574-HS plate backstop. Fits 30A,30B,254
-0576-HS spring backstop. Fits 30,30A,30B,254
-110-HS lever. Lift trip. Fits 30A,30B
-112-HSA lock pawl. Fits 30A,30B,254
46-HS hold down fit 10,10A,30,30,40,41
049-HS spring
050-HS bolt,nut both are for grass board, fits 10,10A,20,30,40,41,250,253,254
045-HS knife head fits 10,10A,20,30,40,41
01483-HS hold down, third from inner end, drilled for hold up rod. Fits 250,253,254
0570-HS hold down fits 30,40,41
0571-HSA outer shoe fits 30,40,41,250,253,254
01071-HS pitman strap
01072-HS pitman strap
040-HS or B-1002 ledger plate beveled edge, fits 10,10A,20,30,40,41,250,254
0145-HS hold down fits 10,10A,20,30,40,41,250,253,254
K-1232 guard bolt 7/16” X 1-1/4”
K-1233 guard bolt 7/16” X 1-1/4” trimmed on side to fit
K-1234 guard bolt 7/16” X 1-1/2”
Let me know if you see anything or if you don’t I can look. Lots more available.
Also lots of other hardware, keys, washers, etc.
518-767-3058 please leave a message. Or Michaelzakens@gmail.com
Thanks
pdrsar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdrsar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 2:46pm
Hi! I'm interested in one of your 028-HS wear plate fits 10,10A,20,30,40,40H,41,250,253,254. Please let me know if you have one. Thanks.
Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 8:26pm
051-HS grass stick holder. Fits mowers.
0338-HS1A inner shoe, fits 30,40,41 mowers
