NOS new idea mower part fs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: NOS new idea mower part fs
    Posted: 04 Mar 2025 at 3:29pm
Hello
Have some nos new idea mower parts for sale.
Some might fit more then what iv lister.
028-HS wear plate fits 10,10A,20,30,40,40H,41,250,253,254
037-HS wear plate fits 10,10A,20
0118-HS pitman head plate fits 10,10A,20,30,40,41,250,253,254
0119-HS pitman bar reinforcement strap fits 10,10A,20,30,40,41,250
0127-HS cam pitman fits 10,10A,20,30,40,41
Also the little wrench 0129-HS,0130-HS pipe
081-HS pitman strap, plain front. Fits 10,10A,20,30
080-HS pitman strap rear, fingered fits 10,10A,20,30,40,41
130-HS upper front wear plate fits 30A,30AH,30BH,40H,41
167-HS gag bell crank fits 30,30A,30AH,254
029-HS shim lower rear wear plate fits 10,10A,20,30,40,41,250,253,254
0673-HS upper front wear plate fit 30A,30B,30BH,40,41,250,253,254
0103-HS spring fits pawl ratchet hub 10,10A,20
0144-HS ledger plate fits 10,20,30,40,41,250,253,254
-0573-HS backstop bracket. Fits 30A,30B,254
-0574-HS plate backstop. Fits 30A,30B,254
-0576-HS spring backstop. Fits 30,30A,30B,254
-110-HS lever. Lift trip. Fits 30A,30B
-112-HSA lock pawl. Fits 30A,30B,254
46-HS hold down fit 10,10A,30,30,40,41
049-HS spring
050-HS bolt,nut both are for grass board, fits 10,10A,20,30,40,41,250,253,254
045-HS knife head fits 10,10A,20,30,40,41
01483-HS hold down, third from inner end, drilled for hold up rod. Fits 250,253,254
0570-HS hold down fits 30,40,41
0571-HSA outer shoe fits 30,40,41,250,253,254
01071-HS pitman strap
01072-HS pitman strap
040-HS or B-1002 ledger plate beveled edge, fits 10,10A,20,30,40,41,250,254
0145-HS hold down fits 10,10A,20,30,40,41,250,253,254
K-1232 guard bolt 7/16” X 1-1/4”
K-1233 guard bolt 7/16” X 1-1/4” trimmed on side to fit
K-1234 guard bolt 7/16” X 1-1/2”
Let me know if you see anything or if you don’t I can look. Lots more available.
Also lots of other hardware, keys, washers, etc.
518-767-3058 please leave a message. Or Michaelzakens@gmail.com
Thanks
pdrsar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdrsar Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 2:46pm
Hi! I'm interested in one of your 028-HS wear plate fits 10,10A,20,30,40,40H,41,250,253,254. Please let me know if you have one. Thanks.
Pete
This page was generated in 0.103 seconds.
