no till corn planter ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: no till corn planter ?
    Posted: 28 Jun 2023 at 1:50pm
looking to buy 4 row no till planter.
Needs to adjust planting width 30" to 38"
using JD 494 now but seed shoe often gets rock or sod stuck in front of it and completely plows out the seed bed. we have LOTS of rocks.
looking for Allis or other no till planter.
1'st question:
will no till work in plowed ground ? "as an option"
if needed.
#2
is there a down fall using airplanter as aposed to gravity seed drop ?
FYI: I am looking at older equipment so repairs/maintenance is a consideration.
#3
which planter should I look to buy ?
Allis
white/oliver
international
ETC.
#4
Which planter should I stay away from ?
FYI; Hobby farming..
THANKS IN ADVANCE
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 2:27pm
I’m assuming you’re planting corn?
People planting food plots ( living bait pile) around here have driven the price of 4 row planters way up.
You didn’t list Deere, and this is an Allis site, but Deere really is a good planter. If you want to do a good job, albeit a small one, of planting corn, upgrade your vintage to past the mechanical plate metering of the old Deere and Allis. Go to finger pickup. You can retrofit this to an old planter but it’s pricey, better off to just find one that way.
White makes a good planter too.
I guess we need a scope of what defines “hobby farm”, budget, work window, etc. I just upgraded from plates and dry fertilizer to vacuum and liquid and I think I died and went to heaven! Don’t know if they even made anything like that that small, but I have seen 6 row ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 3:33pm
Grandpa's farm has been neglected till we moved back here 2 years ago.
Main purpose is for deer food plots and to reclaim hay ground that has been neglected for 30 years.
Love turning over ground with mold board plow. But not necessary after 1st plowing.
planting heirloom corn at the moment.
plan to plant beans at some point too.
my current seed expences is:
planting expences and harvesting expences....
not interested In liquid firtilizer.
vacuum planting? or
is that the same as air pressure planting ?
I run all Allis Chalmers tractors but have found much knowledge on this site on farming techniques and other farm equipment
"good and bad"
share your knowledge please.
thanks in advance
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 6:38pm
Deere or a Kinze all the way.   Local had a Duetz Allis planter our Deere had picket fence stands next door the DA had far from consistent spacing.   Allis made good tractors but couldn’t hold a candle to Deere planting equipment. In my area doesn’t matter the color tractor pulling it it’s a Deere or Kinze planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 7:02pm
In my opinion- I would not deal with a planter- if your not gonna use a combine, rough up the ground , and just broadcast it,, drag it with a cedar tree and hope it rains,,
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 7:43pm
I'm a fan IH air planters  .  Has single point fill and single point seed clean out, three chains total.  Very simple design very reliable.
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 9:09pm
John Deere thought so much of there planters that they scratched to whole design in 2014!
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 9:32pm
I’d vote a white. 5100 or 6000 would do you well. As much as I like Allis. I would not own an Allis planter mainly because of parts availability
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 9:41pm
Well, I’m a fan of AC no-till planters. A 300 specifically, a 2 row version. Not sure of 4 row model number but they are good planters. Actually planted corn today for a corn maze for my buddy. Don’t know anything about a Deere or other brands but I
the AC no-till is a good one.
Edited by AC720Man - 28 Jun 2023 at 9:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 10:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 10:48pm
nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2023 at 10:52pm
nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 1:31am
I couldn't use my Allis planter this spring. borrowed a 800 IH air planter, I knew nothing about it and it shows. very bad planting job done. it skipped alot in the rows and some rows didn't plant and they were not the same rows every time. the blank rows are now growing after 1 month in the field. I used to have an IH #56 planter that was a good one, i've owned about every brand around and my Allis planter would always do thye best job. deere copied Olivers planters made back in the 60's. Oliver did have a good planter too, one all deere farm locally tried out a DA planter when they came out, and ended up buying it, said it planted so much better than their deere planter, they used it for many years, and others seeing what they were using also bought the DA planters. I keep looking for any Allis planters near me for sale or on auctions, they are simple and work well. yes...no til planters will work in plowing, but if you want a smooth seed bed, wellyou know what to do for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 2:37am
I was just looking on BIG IRON auction (todays auction) and there is an 8-row Allis planter on it, 3-pt mount, on a tool bar, that would be adjustable to about any spacing you want. right now the bid is at $135.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 5:19am
Had a 13 row 19 inch bean planter once that was 2 point hitch.   Unless you have all perfectly straight fields mounted planters are not fun. They don’t do curves well.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 5:43am
Best cheap no till planter built was the IH 800.  I'd think a 4 wide could be slid in to narrow, but it'd be far more work than it's worth to do it a lot.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 6:01am
curious am I..
why the need for adjustable rows if you're just feeding deer ?
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 6:28am
I think for your goals, just making sure it is not beat to crap is mostly what matters. If you want ro improve your performance down the row, yetter makes a lot of attachments that can fit nearly any planter. Deer sre going to eat it even if the spacing isn't great
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 6:29am
    Howdy Jay,
    I think I have a answer to your question. More Deer per row!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 7:14am
curious am I..
Well, if you're after the big bucks you might want to have wider rows!Beer
To be serious to your question.
When my farm was enrolled in the CRP one of the changes was to divide field in thirds with a 30 foot wide strip and plant food plots on these 30 foot wide strips, planting half of width, rotating to a 15 feet wide , not to exceed 10 Acres total.
The reason for thirds is for control burn, chemical burn.
Clear?
So a 6/30 row puts in a 15 foot.   A 2 row will put in a 1-1/2 round for the 15 foot width.
I rotated milo, soybeans, wheat.
I used a AC No-Til 2 row set on 30 inch planter.
I had three fields and could go field without a lot of back tracking. BeerBeer
Edited by JoeO(CMO) - 29 Jun 2023 at 7:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 7:47am
Macon, for what you’re describing, yeah it’s not going to matter a whole lot. Unless you want to take some sort of pride and joy in a picket fence stand that all emerges within an hour of each other, who cares, the deer will eat it. That’s something I try to avoid! Lol
You can read volumes on who copied what when, if you want, but who really cares? The Kinze case is pretty entertaining stuff, and it’s cool that David slays Goliath once in a while. The funny part to me, is most people on here love the Kinze story so much because they hate Deere, Kinze didn’t get in trouble for copying Deere because Deere copied Oliver, who probably copied parts of many others on down the line. It’s how development works. I just think it’s ironic that Kinze is a hero for literally doing the same thing. Yes, I get it, he exposed Deere. So be it.
Truth is, if you want a planter that’s easy to get parts and service, get Deere, Kinze is basically a Blue Deere, White, or go on down the line or go collector shopping.
Shameless knows probably the only guy in history who made that comparison and conclusion.
The older plate style stuff did “ok” for their time. You will play hell getting seed that’s sized and graded adequately for plates anymore. But again, you’re feeding deer, so…?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 9:33am
Edited by Macon Rounds - 29 Jun 2023 at 9:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 9:51am
not sure how the saw mill photo got in there.
Edited by Macon Rounds - 29 Jun 2023 at 9:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 10:05am
mabe even this
Edited by Macon Rounds - 29 Jun 2023 at 1:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 4:29pm
yes...i'll be going back to the plate type planter as it still does a great job of planting. as for being able to get graded sized seed corn, i've had no problem from any seed companies getting it. 2 seed reps told me they still sell sized seed because there are still alot of that type planters being used, mostly in the east. they are alot less in numbers than before, but still alot of them out there. i useed an 8-row wide planter for years, was a 3-pt mounted planter, did a great job too, none of my fields are square. our past renters could plant curves with their planter but couldn't combine them, leaving corn on the ground every time. I don't need to plant 7-9 MPH. 4-5 works just fine for me.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 6:29pm
Three point smaller planters are great for tight spaces where you don't have a lot of turn around. Tow a hitch if you have space to waste -- but never back up ;)
Planting heirloom you'll need more pitch/seed spacing in a row. I could plant hybrid popcorn at 6.25in and works just fine (32k seeds/ac). Heirloom needs 8-12in (24k/ac) or you get silage corn. I grew Reid's Yellow Dent last year and had some reach 14ft high with an ear over 8ft high so they like elbow room. I thought corn that high might keep the deer puzzled, but they figured it out.
Plant blue/red heirloom corn for highest protein, can be five times more than modern hybrid/GMO corn. Yellow heirloom is in the middle. Important if you plan to grind for feed or cornbread. Deer can sort corn by protein level.
Sleigh shoes work great in fitted ground, but that's more effort. Keep crops or cover crops in the field after the first year of sod busting and you can notill.
Also searching for a notill setup, I didn't get one this year. I set my cultivator at 30in to strip till rows then followed in those cuts with my 30in shoe planter. Works alright. Possible to do in one pass by dragging the planter behind the cultivator. Or hook up two tractors so one can follow the other.
Get larger round plates to plant ungraded heirloom seed. Doubles can be pulled later.
Early to mid September, broadcast rye in the field and drag or disk it in lightly, 2-3bu/ac. Let it grow in the spring until as late as you can go as every week rye mass doubles (3rd week of May for me), plant the corn. When it emerges or up to V1, roll terminate the rye with a cultipacker (fancy folks use a roller crimper). Pollen stage is best but don't stress. Early spring oats are another alternative. Then you can grow corn without herbicide sprays. There's a farmer doing this on five thousand acres, so it's a good system. You can roll the rye earlier but when terminated flat on the ground it decomposes fast and you need the crop big enough to shade.
Larger mixes of cover crops, 8-12 species, can replace npk fertilizer with fertility, some this year some builds for next year.
Buckwheat and daikon radishes flower and bring in beneficial insects to avoid insecticide needs. Spiders as big as your thumb can eat a lot of pests.
Fields will look somewhat shaggy as you get the skills down, so make sure to mix sunflowers out there as neighbor comment deflectors. Some weeds help improve soil too.
Any inter-seeding summer covers and npk replacers target to sprout after the corn hits v6 so it's done counting ear rows.
This fall I'm adding alfalfa to my winter rye cover, but it needs earlier planting to survive the winter here.
That's my journey in the wilds of Regenerative Ag. I grew up in conventional tillage/chemicals corn and produce. Wish I knew some of this back when I was commercially  growing pumpkins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 7:33pm
You said that once before and I asked you for details and you didn’t provide any. I tried 4 seed companies and have had very limited luck. Yes, they tell you the weight per unit, but don’t put a plate size on the bag like they used to. You can reference weight to plate number, graded round or flat, sometimes with decent results, other times grab a random handful of seed and lay the plate in there and you will see the problem. Had two of the four seed companies promise it would be fine and it was far from it. You’ll get doubles and even triples. Don’t act like I don’t have a clue on this, I’ve fought the battle 6 years. I got good at it. Medium weight FLAT seeds will give the most consistent results.
This year? Put the corn disc in, set the gears, had perfect population and picket fence stand, even with two size seeds in the same box. Hallelujah!
But what do I know?
Edited by Tbone95 - 29 Jun 2023 at 7:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 8:19pm
I found that true yesterday also Tbone. Bag did not have that inf on it like I have seen in the past. Grabbed a handful of seed,, laid seed in the plate to make sure random seed fit well. Rotated the wheel and watched the corn hit the ground. Added more corn to allow plate to pick it up on its own, rotated again to make sure it was dropping correctly. Made a 10’ pass and checked each row for seed drop. I was satisfied with the results and continued to plant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 9:49pm
iam gonna have to take notes when I re-read this.
thanks fellas !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2023 at 10:03pm
i always check the seed with the plates, my bags this year showed I should use the B1 jd plate with the seed. said so right on the bag. you have to tell your seed rep what you want, not what they will just give you!
