No oil pressure
Larry in Ill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Topic: No oil pressure
    Posted: 02 May 2012 at 10:57am
The belt on my C was a bit loose overheating the engine and I lost all oil pressure.  I was unsuccessful in priming the pump.  Before I split it, what are some tricks to prime it and what could have happened?  It does have a Wix fiber element filter.
Thanks for any ideas
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 11:05am
Read this....
I went through this also, not too long ago.
Galatians 5:22-24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 12:23pm
Thank Don,
At least I will know what to look for when I split the tractor.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 12:26pm
Take the line off just before the oil filter and shoot some oil up the like several times. Reattach and start. Give a few seconds and the gauge should start going up to normal again.
Can't fix stupid
This page was generated in 0.049 seconds.
