No brakes |
bamaboy
Topic: No brakesPosted: 15 Nov 2016 at 2:54am |
I don't have any brakes, in fact it seems like the pedals don't even move. We are moving to our land next week and then I can devote some time to our tractor's issues; brakes, rear PTO, cutting deck not turning, and some electrical. It looks to be pretty involved getting into the brakes, and I see new linings for sale, but I've never had to rivet linings on before. Is it necessary to have a special tool? Can pop-rivets be used?
talntedmrgreen
Joined: 25 Jun 2013 Location: Caledonia, MI Points: 477 |
Posted: 15 Nov 2016 at 9:49am |
What sort of machine are we talking about?
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
bamaboy
Posted: 15 Nov 2016 at 8:04pm |
Oh sorry, I have a 616
Bird76Mojo
Posted: 16 Nov 2016 at 2:32am |
I've never seen new brake parts available for the Powermax line of tractors. I have the same problem as you do, on my 720.
GB :) |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 16 Nov 2016 at 5:14am |
Rick Corder on this site does brake and clutch work for a living. Get with him and he can set you up.
AaronSEIA |
farmtoybuilder
Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
Posted: 17 Nov 2016 at 10:30am |
Brakes hardly got used on most of them. They could have a glaze on them. Which can be taken off using a wire wheel on grinder or even rough sand paper. If they are worn out you should be able to get relined from Rick or Local clutch-brake shop.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5474 |
Thanks(1)
Posted: 23 Nov 2016 at 7:43pm |
Parts for 620/720 are availible. The brake pads and disc asembly is located in the drop housing. The brakes operate very similar to my 190xtd. The brake pads squeeze the disc actuator causing three steel balls(4 in my xtd) to roll up a ramp, forcing the actuators outward against middle disc assemby and to the outward shim plate. That's your breaking force, not the brake pads them selves. The main reason for brake failure is the balls get rusted along with the ramps that they roll on. Pads and disc usually are in good shape unless of course you use the brake a lot. Lets face it, with hydro, brakes get used very little. So, here is my 2 cents. Remove the rear wheel, the drop housing from one side at a time. 4 bolts i believe. The whole drop housing comes off. You will see the outer disc or shim plate as its called, brake actuator assembly in the rear differential housing after you slide the shim plate off. Most likely lots of dirt and grime. Pull the actuator out and take pictures so you know how to put it back together. Disassemble the actuator on the bench. Carefully remove the srings, inspect the balls and raceway they ride on. if they are flat spotted, they have to be replaced. Inspect the raceway. 90% of the time a good cleaning of all parts is all that's needed. I take a small rotary tool with a firm brush and clean the raceway and steel balls to get them nice and shiny again. If there is lots off greese or oil, the inner seal is leaking and it should be replaced at this time. It should be dry in there. Place the balls on the raceway and test for easy movement. Now, I put a small amount of antiseize on the ramps and roll the balls around. Test the actuator with balls in place and twist the the 2 parts. This can only be done in the palms of your hand with no springs attached. The balls should roll up the ramps and force the actuator apart. If it works correctly, reassemble the actuator, and reassemble the drop housing. You can test the brake before you put the wheel on by having an assistant to push the brake and try to turn the hub. Then, do the same for the other side. About 1.5 hrs each side.
AC720Man
Thanks(1)
Posted: 23 Nov 2016 at 7:49pm |
I would post pictures but I don't know how to do that.
AC720Man
Thanks(1)
Posted: 23 Nov 2016 at 7:50pm |
i meant by removing the drop housing, not in the actual drop housing. sorry guys.
bamaboy
Posted: 24 Nov 2016 at 7:07am |
Thanks, I will get to that soon, very good info. The only time I've missed them is when I'm trying to raise the hitch-ball into a trailer.
