New wd45 |
Page 123> |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8654 |
Topic: New wd45Posted: 01 Feb 2020 at 6:16pm |
Ryan,
You will really like the upgrades to the electrical system too. I wire my own but Steve @B&B has complete kits too. All those little details add up to smooth running tractor for a long time! Regards, Chris
ryanschott
Posted: 01 Feb 2020 at 11:28am |
Just got some time to mess with it yesterday. It rust good but seems louder and harsher then should be. So I tried a little timing adjustment and it purrs. Wow what a big difference a few degrees makes. Just waiting to make a little extra cash and will be getting a new alternator and a wiring harness cause absolutely nothing is savable with the wires. Plus I’m going to get anew exhaust manifold cause the one end leaks and manifold is just ate out a little on the end. But local junk yard has a old d17/combine motor with new looking Vinson manifold and going to grab distributor too
Sugarmaker
Posted: 11 Jan 2020 at 8:25pm |
Ryan,
Congratulations on your WD45 engine overhaul! Looking forward to the video too. Those manifolds get washed out on the ends. That's pretty common. A machine shop can true it up for you. Regards, Chris
ryanschott
Posted: 11 Jan 2020 at 7:55pm |
It runs good had it running for over an hour today. Fired right up everything sounded great. A little louder exhaust wise but I’m the barn. Has a small manifold leak cause the far corner is rusted a little so might put an extra gasket in or get new manifold. Drove it around the yard feels very powerful compared to ones I had in the past. You can dump clutch and it doesn’t stutter just goes. Next I guess is work on the electrical system which needs to be completely replaced cause every bit of it is junk. Am very happy with how it turned out. Will put up a video when find out how.
Ryan Edited by ryanschott - 11 Jan 2020 at 7:56pm |
Sugarmaker
Posted: 03 Jan 2020 at 8:28am |
Ryan,
Your getting there! Somedays it seems like not much is happening. Also sounds like you have another potential project. If you can find a styled WC that seems to be the hot set up to get the weight down as much as possible for the Z engine. Looking forward to your updates. Regards, Chris
MDWilliams338
Posted: 03 Jan 2020 at 5:27am |
Nice job for sure...looks good
It isn’t how you die.It’s what you live for.-Daniel Boone |
ryanschott
Posted: 02 Jan 2020 at 8:40pm |
Hopefully next week will have tractor running just waiting on a muffler now. Was going to buy a new one but the boneyard near me has a gleaner d17 motor on the skid still out of combine and looks good and has good muffler and Vinson manifold for cheap. . So going to wait till pay day next week and get that. Maybe do a gleaner powered puller like sugarmaker is working on. My thought where to do wd and strip it down to extreme lightweight class. I will get new muffler when I repaint tractor but for now use what I will have. But Tractor is coming along good just anxious to get it started and make sure everything gets lubed up and no problems. Then next thing will be to do electrical system which will be 12v with one wire alternator found a awesome wire harness from brillman at good price looks original and wired for the one wire. Plus I think headlights will get led inserts under the glass bulb. Look old but new. So hopefully will have a awesome update next week. Hope everyone had a great new years
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18962 |
Posted: 19 Dec 2019 at 9:27am |
It's really coming together for you Ryan.
It looks good and it'll be running before you realize it. And then WE want a picture of your expression when you pull that starter rod!! |
ryanschott
Posted: 18 Dec 2019 at 10:19am |
Have the fuel delivery system all together. Just need a muffler, plug wires, a hotwire, and need to seal hand clutch cover and it should run. But all those things on Xmas list so might have to wait till then
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 17 Dec 2019 at 9:56pm |
My son put Ford 302 exhaust and Chevy 350 intakes in my 45. Some he had saved back. (used) I couldn't believe how much better it started and ran.
David (in Mi.)
Joined: 05 Jan 2010 Location: Croswell, Mich. Points: 157 |
Posted: 16 Dec 2019 at 9:51pm |
The Kerrigan dealer in Croswell was one half mile west of town, on the south side of the road. The building is still there, someone is selling lawn mowers and some farm supplies there now. The dealership In Sandusky has a lot of history. I know the owners personally, it was called Cork Impl. for many a years. The owner was Bob Cork which I have known forever. He has died, I still talk to his son in Arizona. After he sold out (about the time Allis sold) the new dealer was Meull Impl. until if finally when broke and no more Allis That dealership was straight across the road from Sandusky Middle school on M 19.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8966 |
Posted: 14 Dec 2019 at 10:34am |
Experience is a great teacher. You should have had the manifold side milled while it was off.
Sugarmaker
Posted: 14 Dec 2019 at 7:20am |
Ryan,
Your coming right along on the 45! Thanks for the updates. It will be ready to do some work this spring! Regards, Chris
ryanschott
Posted: 14 Dec 2019 at 6:09am |
In Goodells. Where about was Kerrigens I’m a little familiar with croswell. That’s awesome to know the past and And dealer it came from and twice as awesome when it’s family and you where there. Do you know the name of the allis dealership in Sandusky. Just finishing up the head and working on fuel system just got new fuel line and nos sediment bowl assembly. It’s getting close to being able to run. Going to be putting in new manifold studs and manifold then should be ready to rip and roar.
David (in Mi.)
Posted: 13 Dec 2019 at 9:18pm |
Enjoying your thread Ryan. Where are you located?? I live just north and east of Peck. Know all the people you where talking about in area. My 45 Diesel I have restored came from Kerrigens Impl. in Croswell in 1955. My dad bought it brand new with a 12' transport disc. I remember the day, I was 6 yrs. old. Keep up the good work.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 09 Dec 2019 at 5:00pm |
Looking good, Ryan. I'm enjoying your thread. Looking forward to a video of that engine running!
WC, CA, D14, WD45
ryanschott
Posted: 09 Dec 2019 at 11:32am |
Got the head on and rocker arms bolted down. Now need to set the rocker clearance and can finish up the motor. Found out the gas line is plugged solid with who knows what. Air wouldn’t blow threw it then have to work on manifold, wiring, and fuel system. Going to order a one wire alternator and brillman’s has a nice wd45 wire harness made for one wire alternator. Just need to save up a little money. Got new gas tank on there looks very clean inside but doesn’t have the numerous vent holes on the bottom side. Anything else you guys can think of I need to check I may have forgotten. Oh the air filter was filled with tons of crap what a mess. Might have original tar oil in it.
Posted: 05 Dec 2019 at 3:55pm |
Leave the spark plugs out and crank it with the starter and a battery charger. don't overheat the starter.
ryanschott
Posted: 05 Dec 2019 at 3:06pm |
Any way to prime oil system so it’s pumping the second it starts or does it usually prime pretty quick
ryanschott
Posted: 02 Dec 2019 at 3:13pm |
![]() Got time to work on it today I now have an oil pan on it now. Looks like it went on good thanks to using those clips. I had never seen those before worked awesome. Also no swearing so must have been good. Also put all new guts in the distributor so that’s ready. I do need new plug wires cause they look kind of crappy. Have two more valves to do and I can put the head on. Got a bunch of odds and ends like fittings for oil line was bad and one got smashed. Want to also paint the head and valve cover. This week when I get paid I found a nice gas tank on eBay I like so just going to do that instead of messing with the rusty tank. Still a lot before it can run and use it. I need to completely rewrite it. Need a alternator and I’m sure a few other things. The pivot on the hand clutch is so rusty it barely moves so that needs attention also. But getting there. maybe this month I’ll rig up at battery and get it to just run. |
Sugarmaker
Posted: 29 Nov 2019 at 7:23pm |
Ryan,
I dont think you will regret going to 12 volt system. I like the way they start. On the piston dimension below the deck IIRC that 1/2 inch sounds about right. Here is a example of a WD45 I did last spring. ![]() Regards, Chris
ryanschott
Posted: 29 Nov 2019 at 6:20pm |
Well ordered a 12v coil so I guess it’s going that way. What is easiest and cheapest to use for a alternator there used to be a small parts store that closed up near me I would get alternators for $35. But that was 10 years ago
ryanschott
Posted: 28 Nov 2019 at 3:03pm |
Just a lot off b or c motors seems like those pistons come right to the very top. Haven’t done a 226 motor in awhile and can’t remember must be getting old.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34602 |
Posted: 28 Nov 2019 at 2:47pm |
Were the other engines with chambers in the head or were they flat like this engines head is...? Looks about right for piston height, but, if you put WD pistons in that WD45 crank... you will be high compressioned. Pullin tractor time![]() and just buy 4 new exhaust valves and put in.
ryanschott
Posted: 28 Nov 2019 at 2:27pm |
4 1/8 bore not sure on ratio. Can’t wait to hear it run
SteveM C/IL
Posted: 27 Nov 2019 at 9:50pm |
Don't have much experience with these engines so I can't say if piston height is weird or not. Does seem a little low. Where'd they come from and whats' advertised C/R? Overbore or STD?
ryanschott
Posted: 27 Nov 2019 at 7:43pm |
![]() ![]() Ok progress is coming now got the sleeves and pistons in and hopefully tomorrow will have the pan on might be next week but should be done with the head and put that on. A little setback is the gas tank had some rust in it so took of to dip and clean and when I first looked in it now out in light there lots of vent holes on the bottom so not sure if I’ll will put patch on the bottom and line or buy another tank. Still also on the fence is 6v or 12 v the generator looks nice but all the wireing is junk and coil looks bad too so am leaning towards 12v. Also other motors I have done in the past the pistons seem to come almost flush with the top but these are as high as they go in the pics. All in all it went together very good and feels good. Used assembly lube on this motor i like it better then just oil. Am very pleased with the progress so far |
savedallis1953
Posted: 08 Nov 2019 at 12:04pm |
About 18 years ago I acquired a 1938 unstyled WC with a 6' side mount sickle mower. From the state of Delaware. Did a "field rebuild" i.e. lapped the valves and honed the cylinders w pistons in place. No spark from the mag so put a battery n points ign. in her. Ran great. My 28 year old friend has it now and still running, he's hooked.
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
Sugarmaker
Posted: 07 Nov 2019 at 5:40pm |
Ryanscott,
Good progress! You will be happy with the rebuilt engine! Regards, Chris
ryanschott
Posted: 07 Nov 2019 at 12:04pm |
Just order the piston sleeves and ring kit so should have some more work getting done on this. Kind of sucks cause it’s getting cold out so have to fill up the heater. Also does anyone have two nice used exhaust valves they wouldn’t mind parting with. Just need those and head will be back together. Maybe will have running this year.
Page 123> |
