new toy
Bled Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Topic: new toy
    Posted: 24 Mar 2014 at 10:14pm
just got new toy a d17. got her at auction well stole her realey. just need to know how big ci I can get and how hp I can get.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 5:02am
Depends on how much money you're willing to spend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 10:37am
I no that much. just want so info.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 4:33pm
with Alot of work you can get 400 cubes HP i am not sure what it will produce you  need to talk to wi50
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 5:26pm
You better figure out where and what type/kind of "pulling" you are going to compete in. Sounds like another wannabe Puller who doesn't really have a plan.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 8:09pm
Unless you have some pulling experience, walk before you run. Try pulling in some stock antique classes, until you get some ideas about weight transfer, balance and traction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 9:30pm
well I have about 30 years of pullin from garden tractors farm stock tractors 4x4ss trucks and of right now a 4800lb ss 2wheel drive. I ant no wantabe just lookin for some info. if you don't want to help that's fine .I have farmed ac for 54 years. just thought this sight was good and did injoyed it. but anyway class is 7000 farm and field.no speed limet no rpm limet.410ci limet.sorry bout spelling. if you cant help that's ok. thanks
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 9:33pm
Try the YTmag pulling forum, ask for a guy that goes by pankey.....
IL-D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 9:44pm
for the class you speak of your first step should be get a bigger tractor!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 9:53pm
thanks don't know what ytmag is.have a 180,185 but wanted to play with the 17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 9:54pm
forgot to say the class is no trubo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 10:35pm
D-17's belong at 5,500 lbs and under to be competitive.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2014 at 11:36pm
If it's a non turbo class a 301 gas engine would be a much smarter choice @ 7,000 lbs. Whether it's in a 180 or 190 doesn't really matter. The 180 would be a little lighter I suppose. A D 17 has no business in that class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 7:41am
I certainly didn't mean to antagonize you. I was merely pointing out that you need experience before jumping in too far.
As the others said, a D-17 is just too small to be competitive in a 7000 lb. class. You will be competing against 560's, 88's, 4010's and a lot of other tractors that are a lot more cubic inches. It would be frustrating and, probably, down right embarrassing to be out classed so bad.
If you were building a tractor for a 4500 lb. class, a D-17 might be able to be competitive, but it is just too small for 7000 lbs.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 9:38am
YTmag.com is another forum. (Yesterday's tractors).
They have a pretty good pulling section.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2014 at 5:07pm
they did till everyone went to the new pulling page on face Book
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2014 at 1:04pm
well wf I have experience,maybe not pros like you dr.allis. thanks to you other guys for info the 180 was may first chouse but got this old 17 and thougt I ask.going to play with the pump and timing should get around 100hp and putin on 30 or 34 on the 180 and see what happens. some other good info will be helpful. thanks
CA, D14, D17, D17VI, 180, 185, IH 140 and one damn deere
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2014 at 3:34pm
It helps when your opening statement is specific. It happens on this forum all the time with someone asking a very general question to a very specific situation. Your third post gave us a little something to work with. The first didn't.
Edited by O.P.S. Heads - 28 Mar 2014 at 5:47pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2014 at 6:18pm
So it's a diesel D17? I think you can tune it up a bit, but I don't think a non turbo 262 will get close to 100 hp. Those old design lanova cell engines just aren't very efficient. Maybe 80hp? I'm not saying it won't be fun, or competitive, but it most likely will not dominate. Remember, you don't have to have the most hp, but it does help lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2014 at 6:29pm
Play with the injection pump timing and fuel setting all you want on a One-Eighty, and you won't see 100 HP without a turbo. Best guess would be about 85 HP and a lot of smoke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2014 at 9:27pm
sorry for the miss leading in first post, but never take to being a wantabe. so enough of that. no the 17 is gas the 180 is diesel. some guys I know that are ac men say around 100hp that's why I got on to get some more info. my 185 is turning according to dino a few years ago is at 90 without going all out.thanks will check back later I like good info and any ac tracto tolk not many of us around here any more
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 12:58pm
Glad to have another AC man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bled Orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2014 at 3:57pm
thanks jay glad to be here. sorry if I trek some people off did not meanto. like talkin ac and findin out info.just got back from new club meeting. think we got class set to go first pull may 17. hopen everthing gos good.
This page was generated in 0.122 seconds.
