need spec help on WD |
Nautyboss ![]() Bronze Level ![]() ![]() Joined: 30 Dec 2011 Location: Arkansas Points: 27 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Feb 2012 at 3:51am |
Can anyone provide me with torque, clearance, etc. specifications on the crank and head for my 52' WD?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
I think bearings should be between .002 and .004 for clearance. Sleeves should extend above the deck .002-.004 also.
You can do a google search for torque specs for about any size or grade of bolt. |
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Head Bolts=90ft-lbs; 3/8" studs=25ft-lbs
mains=85 ft-lbs Rods=70ft-lbs(castelated nuts); 40ft-lbs(locknuts) Valves-0.012" hot Valve Springs=2 13/32" free length; replace if more than 1/16" under Liner Stickout=0.002-0.004" Rod nut clamp bolt=20ft-lb bearing cap insert stickout=0.0055" each side(block and cap) Bearing clearance=0.002-0.003" |
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8628 |
Them's D17 torques. WD's were less.17's had better bolts
Guess my Jensales WD/WD-45 service manual is wrong.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
![]() I think I have used up all of my IT shop manuals for fire starting after they send me down the wrong path to many times. The funny thing about burning them up; is they didn't even burn that good for what I payed for them!
Thanks, I appreciate the info. Can you tell me what the ring gap is supposed to be?
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Typical ring gap is .001 to .0015 per inch of cylinder diameter. This is the specification for a new ring. I don't know what the maximum allowable gap would be.
