Need help with part no. on 460 loader
mark-east-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Topic: Need help with part no. on 460 loader
    Posted: 24 Aug 2017 at 11:21pm
Ive looked on agco parts book web site and have not had any luck , my tilt cylinder on my 460 loader is leaking a little and id like to order a seal kit for it if anyone can help with part no. . Its the cylinder that tilts bucket .Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 11:35pm
There was 2 different model 460 loaders. 1 was for the 160 and the other was for the 6060,6080. If its the newer one for the 6000 series I have a seal kit in the shop I can get a number off of.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2017 at 11:41pm
yes its on a 6060  thanks for help .
V8cat359 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote V8cat359 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 5:31am
What is the difference between the two loaders other than the oil reservoir in the left bracket on a 160?
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 8:23am
I resealed both the tilt and raise cylinders on my 6080.  Part #71503831, all 4 are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark-east-tn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 8:55am
Thanks I'll check with Brenda and see if she can get me one , thanks again for the help .
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2017 at 2:50pm
That would be the exact same place I got mine.  Sandy Lake is great to deal with.
Tswarner67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tswarner67 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 4:24am
Touching base on this post . What’s the difference between this and one for the 160? My 160 tilt cylinder is leaking pretty good . Would the same kit work for it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 8:13am
Two completely different loaders built years apart. A 460 loader for a One-Sixty tractor uses seal kits from the 400 or 500 series loaders as used on the D-series primarily.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:40pm
www.awtractor.com
A&W TRACTOR 920-598-1287
This page was generated in 0.054 seconds.
