Need HD5G transmission parts |
youngrkp
Joined: 05 Dec 2010 Location: Danville,IA Points: 10 |
Topic: Need HD5G transmission partsPosted: 30 Mar 2020 at 7:49am |
The transmission on my HD 5G locked up and I am needing the reverse idler gear needle bearings and also the bearings for the input shaft. Where could I find them? What are their part numbers?
Thank you I forgot to mention that my crawler has the older single speed reverse transmission. Edited by youngrkp - 31 Mar 2020 at 9:03am |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 30 Mar 2020 at 3:18pm |
Gemdozer probably has it
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1008 |
Posted: 30 Mar 2020 at 4:20pm |
One of our local suppliers has a well thumbed paper copy of an (IIRC) "IBR Bearing Replacement catalogue". If you have the manufacturer's bearing part numbers it gives you the original bearing manufacturer and their part number(s). For instance it went from the Allis part numbers for needle bearings in the steering box of an AC 45 grader to the Torrington numbers - which were bearings still available. So if someone has access to one of those - - - . Even better is the parts book for our FA 10 dozer has a table at the back which does the same thing for its Fiat bearing part numbers - though that isn't going to help your enquiry
Edited by Ian Beale - 30 Mar 2020 at 4:21pm |
youngrkp
Posted: 31 Mar 2020 at 9:08am |
What is the best way to get a hold of Gemdozer?
gemdozer
Posted: 31 Mar 2020 at 1:01pm |
I have these used transmission parts .
gemdozer@hotmail.com
dadsdozerhd5b
Joined: 27 Sep 2009 Location: lansdale pa. Points: 537 |
Posted: 14 Apr 2020 at 8:17pm |
new are available. I put them in a trans last year. get part numbers and search for on the internet, look hard and you can find less expensive but good bearings, sometimes new old stock. I will see if I can find my notes.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42253 |
Posted: 18 Apr 2020 at 10:34pm |
AC used stock bearings and can be sized using dementions from bearing house .
Well all except front idler bearings , cups are standard cone is hard to find . rear Link belt outboard axle bearings are also a hard to find bearing and kind of AC only this is HD5 and HD6 - unsure on larger machines |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35569 |
Posted: 19 Apr 2020 at 5:24am |
Similar style my HD7G |
