need drive sheave
DanNESD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Topic: need drive sheave
    Posted: 26 Jul 2010 at 1:04pm
I need the drive sheave assembly for a #5 mower going on a B (part # 70802145) if I can't find the complete sheave the hub (part # 70802147) would help in making one myself.  I need one for  an 1 1/8 PTO shaft. Any help will be greatly appreciated, Thanks in advance!
Dan
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 5:32pm
This the one your needing?    Dale
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 5:53pm
If you can't find an original AC one I would think a 2 piece Browning would work. There is a split taper bushing thats 1 1/8" dia. If I knew what size the pulley is, both diameter and belt width, I look to see it there's a pulley that would work with the 1 1/8" bushing.
Dusty
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:01pm
A number 5 would use a drive sheave with two grooves, and the Outside Diameter would be a little smaller too...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanNESD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 10:41pm
The picture Dale posted is the one I need.  Do you know where I can get one?  The belt is still available through Agco.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 7:10pm
Dan....This is what I have. Thanks....Dale
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2010 at 7:15pm
   all the pulleys i have ever seen have been the  1  1/8 '' size  have one in the barn
