need a 3pt bolt size |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1900 |
Topic: need a 3pt bolt sizePosted: 01 Apr 2016 at 7:10am |
Does anybody know what size bolt goes into the 3 pt bracket that you see in this ebay posting? I'm throwing a 3pt on my 2nd 616 and did not receive those bolts. Would those bolts already be in my non 3pt unit?
Thanks David http://www.ebay.com/itm/Allis-Chalmers-616-620-720-Simplicity-4040-4041-9020-Three-Point-Lift-Arm-/222069303294?hash=item33b45ca7fe:g:iDsAAOSwI3RW-1bY |
ac720nut
Joined: 09 Feb 2016 Location: Dexter Mi Points: 1217 |
Posted: 01 Apr 2016 at 9:54am |
I'm sure I could tell you but can't openposting
coggonobrien
Posted: 01 Apr 2016 at 10:09am |
There are 2 brackets, 1 for each lower link the bolts to the tractor and a pin goes through them for the lower links to pivot off of. I'm need the info on the 2 bolts that go through each of the brackets.
mnoonan-NEWI
Joined: 11 Sep 2009 Location: Marinette, WI Points: 739 |
Posted: 01 Apr 2016 at 10:25am |
1/2"-13 x 2" Hex Cap Screw per the parts book. (2) per side. I would use grade 8. Edited by mnoonan-NEWI - 01 Apr 2016 at 10:27am |
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Joined: 11 Sep 2009 Location: illinois Points: 91020 |
Posted: 01 Apr 2016 at 12:34pm |
coggonobrien
Posted: 01 Apr 2016 at 12:37pm |
Thanks!
