N5
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: N5
    Posted: 03 Dec 2023 at 1:06pm
What year did the 426 in the N5 gleaner change from orange to Black?? Thanks....Dale
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 1:38pm
F2'S CHANGED IN 1980 - ALL  I have seen were black - very few made before 1980?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2023 at 2:46pm
Dad's 79 L2 was orange. 1980 and on are black.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 12:38am
My N5 is serial number 1314 and has the orange engine. I picked up another 426 N5 engine and it is black. I always assume the orange one was a replacement. also picked up a R5 combine.. the 426 has windows on both sides the block at the number one rod. So I should be looking for a late model block 2 replace that? Thanks everyone. Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 1:37am
Orange meant 1979 or older in age. Black was 1980 or newer. Roosa master injection pump was 1981 or older. Bosch inj pump was 1982 or newer. All N-5-6's had 7080/7580 counterbalanced crankshafts with a fluid filled front damper, NOT a rubber damper. Combine crank pulley also unique with dbl belt fan drive and one belt water pump/alt drive.
Edited by DrAllis - 04 Dec 2023 at 1:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2023 at 9:25am
Thanks doc. That exactly describes the situations that I am seeing. And the fluid damper is that other on going discussion in another post? Thanks. Dale
