N-5 R-5 cylinder imput assembly |
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 792 |
Topic: N-5 R-5 cylinder imput assemblyPosted: 20 Sep 2023 at 5:27pm |
Trying to remove the cylinder input assembly but dont have enough room do to the outer sheave hitting the clean grain elevator.
I have removed the nut and washer from input shaft I removed the bolts to the outer sheave ring I slid the assembly outward and removed 8 bolts from the back side of the inner sheave Everything is loose but I have no clearance to remove do to the outer sheave it's hitting the clean grain elevator Do I have to drive both the inner and outer sheaves inward and leave them hanging on the input shaft while I take off the cylinder input spring assembly? Thanks
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8686 |
Posted: 21 Sep 2023 at 8:06am |
You might try a search over on thecombineforum.com
