My Old beater Ford SD |
Page <1 345 |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29994 |
Last barge of month loaded yesterday, will be building stockpiles back up after rains calm back again.
So today, a day with the wife, Grocer, a breakfast stop and a quick tour of a few goings on have been watching. Then finished cleanoff of Left fender, is currently curing two part epoxy primer., R Fender scuffed for the paint attempt tomorrow as well the R Rr cab corner. Will mask it again in morning. IF all goes well and paint does not lift, will be applying Clear to those mid afternoon. Otherwise may end up towed to body shop and leave them do their magic, at a price.
What went wrong was I have NO paint Booth, the materials are designed such that they are Used INSIDE a Controlled Climate Booth, Fixed Temp, Semi Fixed Humidity and Constant Filtered Airflow. Same issue had painting the KW. Today's results. Cab Corner Left Fender right fender Hood line edge repaint Edited by DMiller - 02 Jun 2024 at 4:31pm |
As soon as had the Second coat of Clear on
Allowed to Sit for an Hour, applied Third Clear WET Coat, pulled wrappings. No Lifts, No separations, just DONE!!! Corner is Artificially Bright as the Lighting I was using to actually SEE the work being laid down!! Now can get back to Cut and Buff.
Edited by DMiller - 02 Jun 2024 at 4:38pm |
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1515 |
It's good to see you're back on track.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78711 |
Looks great... never heard the " no reducer" story before ....... ???
i know they use slow, medium and fast evaporating reduces for various outside temps.. Edited by steve(ill) - 02 Jun 2024 at 5:22pm |
The rep noted the Solvent paints formulas today differ from even ten years ago, most shops still have booths even for large trucks so can get away with Medium to slow Reducers. Open Shops, Barns or sheds as I have are NOT conducive to paint work by his acclaim, even trying to limit dust or floating debris is about useless in my setting.
Showed him the paint Pops, he knew right off, Solvent Pop, noted with paint I received to Over Spray a repair area on fresh lain material(Under 2 months), NO reducer unless over 85 degrees otherwise the paint itself would flash far too fast. Not having painted more than a few Lacquer jobs in the 70s then IMRON in the late 70s/80s into more enamel bases in the 90s, and this my first contacts with a HVLP for the KW and this I am completely out of touch.
Worked all week, back at the pickup today EARLY.
Managed to Blend Buff RRr Corner then hung RRr door, adjusted on doors and installed latch works and hardware, BUNCHES of bump or scratch touchups ALL morning as nicked or caught a edge with pieces. Had to run to town and get new hood prop cylinders, the Originals FINALLY said had enough. Tomorrow more sand and buff spots, then install front door glass and operators, finish installing door speakers then Lower door panels the little pieces of Door splash seals on door bottoms and the between door seals and mirrors. IF feel good of it may sand and buff on front fenders ready those to go on along with front bumper. Still have seats to clean, floor covering to install and all the inside trim panels in back. And as yet not ordered rear glass and the sealant for the Rear Side glasses. |
Spent the morning cleaning, Seats, old Carpet assembly, as the new floor mat is Not Worthy to go in. May use it for something else but is just tacky. Did assemble all the front door hardware, windows and operators, speakers, mirrors. Got a little more cut and buff completed until shoulder said WHOA. Carpet is down, started adding trim panels in front section. Rearranged shop to situate the fenders on a pallet on sawhorses to cut and buff, easier on me!!.
Entire last post disappeared, Started OVER!!
Last week a bust, Wife's Birthday and our 38th anniversary, Dinner yesterday at White Mule Rosebud MO. Today back at truck, seats in, Fenders buffed as far as could tolerate on sawhorses, installed those where will go back sand and buff rough spots all around. Added photo of Carpet Cleaning for last post. Have had to order a bunch of small schtuff missed on previous inspects, small install grommets for T/S being some of that. Fenders are mounted, need to massage those into better align next round. Glass will get ordered for rear window tomorrow, may have install done as off next Monday for Doc day. Edited by DMiller - 16 Jun 2024 at 3:52pm |
Was inspecting the replacement cab step boards, mounts will cover the tear drop and small rectangle holes at three of the four locations against birds and mice just not for wasps and mud dobbers. Thinking will install the Aluminum tape I have and use for welding over those holes, maybe even cut up an old inner tube as a backing insulator. Need to keep the vermin out and there is a fourth hole that I will need come up with some kind of covering.
Small round and ovals can use commercial plugs
Page <1 345 |
