More "B" pictures and questions.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: More "B" pictures and questions.
    Posted: 23 Feb 2012 at 5:44pm
What are these brackets for?
What were these Eye-Hooks used for?
Would there be any problem with fuel flow with this filter?
Here are a couple pics of the front weight for those that asked.
Here are some of the 3 point.
Edited by R.W - 13 Jun 2012 at 10:30pm
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 5:56pm
you have a late model B those "pegs" are for the hydraulic cylinder. the "rings" are for use with the snap coupler on a B.
Personally I would not use an inline fuel filter like that. I only use the sediment bowl as a filter.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 5:57pm
The eye hooks look to be in the right spot for a snap coupler and I'd guess all the pins with holes in them are for hyd. cylinders?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 9:36pm
Thanks guys, would you suggest a bigger filter? I like having a extra filter to keep crud out of the carb but one that small bothers me.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 1:19am
Those cast pins with the funny shape on the final drive are also snap coupler pieces.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 4:24am
Nice Beefy weight on the front end and a tractor is in pretty nice shape.
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 5:20am
R.W Some of those brackets look like some snap coupler B stuff.
1 HYD cyl bolt on bracket, (I) bolts on foot rest, and are the draw-bar pins cast and (S) shaped. At second look you do have some snap (B) parts.The front weight is home made. I ya get up by Temperance stop by. I'm off exit 5 on US 23
Have a good one BILL P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 6:41am
As far as the filter is concerned, as long as the filter is designed for gravity feed (small engine/lawn mower type) fuel systems, you shouldn't have any fuel flow problems. It will help trap the debris that got by the sediment bulb.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:38am
I was wondering about them too, I didn't think I seen them on many B's before.
This page was generated in 0.088 seconds.
