Model b wont start need help
 Post Reply Post Reply Page  <123
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 6:48am
The backfiring sounds like a timing issue (to me). Are the gears in the mag timed correctly? The gears (rotor) inside the mag must be timed correctly or the points will not be opening at the time the rotor is contacting the terminal in the cap.
Are you using a Fairbanks-Morse or WICO mag?
If you are using a FM mag, #1 wire should go in the 10-11 oclock position, with the #2 at 2-3 oclock, #4 at 4-5 oclock and # 3 at 7-8 oclock.
If it's a WICO, (I believe) everything is moved clockwise one position so the rotor (pointer) is pointing to the "window" in the cap (I'm not that familiar with a WICO mag) I believe the #1 cylinder will be at 2-3 oclock.
My advice is to turn the engine until it is on the compression stroke. Have someone watch the hole in the left side of the tractor for the "FIRE" mark (forget TDC and time using the impulse). Stop with the "FIRE" mark at the pointer on the compression stroke. The slots where the mag mounts should be nearly horizontal (slightly above horizontal on the engine side). Turn the mag backward until it lines up with the slots. Install the mag. The rotor should be pointing at the #1 pole in in the cap.
If the gears (rotor) inside the mag are not properly timed, you will continue to get backfiring and you could hurt yourself cranking it if it kicks.
Hamblin28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 10:42am
It's a fair banks mag, when i pulled the mag the first time I had the "fire" mark in the inspection cover. I put the mag in a vise and snapped it over checking for spark and they all sparked. So I snapped the last one so it's ready to fire on 1 then put it back in the tractor it was horizontal and slightly up on the motor side. It sparks cyl 1 when the center mark is dead center in the inspection hole. The I followed it through with a helper it fires 2 4 3. My only question is did he time the cam right so if the rain holds off I'll start pulling the front cover to see off the cam and mag gears are lined up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 12:17pm
I think the cam timing is off, we had a short break in the weather so I pulled the carb and cleaned it made sure the float was working properly. Then I followed the spark it fires on 1 but the intavalve starts opening after it fires and the other valves seem to be off. Hopefully the weather is good tomorrow I'll pull the front cover and see what's going on in there hopefully this is the problem. Also he has a ball valve on the gas tank with a inline filter instead of the glass bowl. I found it in the ahead but the lines are missing. So could this be the reason for over fueling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 5:46pm
Your spark is on the exhaust stroke.  You are off 180 degrees.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 6:15pm
There's more askew if the exhaust valve wasn't open as the piston traveled upward before ignition, yet started to open after ignition. Both valves should be closed as the piston travels upward and remain fully closed for the entire downward stroke. It's almost as if the engine was turning backwards - if I understood the description correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 6:24pm
 He said the INTAKE valve opened right after it fired, That means the spark is on the wrong cylinder. That is why you put your thumb on the plug hole to find the COMPRESSION stroke before attempting to put plug wires on and time it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 6:55pm
Sorry I got the intake and exhaust valves mixed up and compaired it to the old one it's the second valve from the radiator that opens after it fires on cyl 1 so it was the exhaust valve opening again sorry I'm new to this I ordered a allis chalmers manual so once that comes in I'll have lots of info on this tractor haha. I didn't realize the valves switch from cyl to cyl that was my mistake. The weather is suposed to be nice tomorrow so I'll work on pulling the front cover and check cam timing. I've never done it so any pointers or tips be for I tackle it? It seems the radiator, starter pully and all that needs to come off before the cover can come off anything else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 7:06pm
Or I guess I could hold my finger over the hole find the compression stroke and try to time it. Im kinda confused as it's timed to the "center" tdc mark or does it fully rotate the fly wheel once for intake and once for the exhaust stroke and I have it timed to the wrong rotation? Can some one tell me a step by step how to time it? I've found the fire mark then timed the mag. The rotor was slightly higher on the motor side not perfectly horizontal. Then slowly cranked it till cyl 1 sparked the center mark shows dead center in the inspection hole so I assumed it was in time so maybe I'm on the wrong stroke or the cam timing is way off I'm confused at this point.
Sorry for all this confusion this is all new to me but I'm trying to read and learn everything I can about this thing so I can rest or it to it's former glory. Thank you guys for being patient with me I appreciate all the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 7:18pm
Yes there are 2 TDCenters. One is the compression stroke and the other is the exhaust stroke. All 4 cycle engines have the timing mark show up twice for each cycle .
 All you should have to do is switch the plug wires out 180 degrees and start it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 7:47pm
Okay so normal is 1243 should it be 4312 is the opposite?
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 8:12pm
you have nothing to lose by switching wires....and its a lot easier than pulling the cover...try it....just keep them in order....sounds like you are 180 out.
If ignorance is bliss, than happy days are here again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 8:22pm
Well I switched the wires and shot some ether in it and it started but died there's no fuel in the bowl so I'll take it off tomorrow and see what's up with it. But it would start for a few seconds till it ran out of either multiple times. Ran out of way light so tomorrow I'll report my findings it may be running good tomorrow thanks to you guys!! My father in law about crapped his pants when he heard it fire it's been over 15 years since this tractor has ran! Thank all of you guys so much!
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 8:24pm
I think that is right 4312. Easy way to be sure you are not off 180. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 8:36pm
It was 180 out it fires off either and ran a few seconds it seems my float is stuck as I'm not getting fuel so I'll look into it tomorrow!
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:34pm
Glad you are making progress. So now you know about TDC on the compression stroke.
I read the thread, maybe I didn't grasp it all, can you please answer some questions?
1) Do you have the hand crank?
2) Does it have an electric starter?
3) What make and model carburetor?
4) If yes to hand crank, how tough is it to crank over?
   If the engine was rebuilt wrong and the bearings are
   not right, when you do get it running it may hand grenade.
   Try to tell us how much effort to crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 10:02pm
It's a hand crank it's easy to crank it does get a little resistance due to compression but with plugs out it spins over with one finger. I can't remember the name on the carb I'll have to look tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 10:08pm
I think it's a zenith I'll look tomorrow and let you know!
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 11:18pm
No matter where you put the #1 wire it still fires 1243. The internals of the engine is what determines the firing order not the cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 6:40am
It sounds good that you can turn the engine easy with no plugs. That engine has a tricky situation with bearings and shims and clearances.
It would not be too hard to get a bearing in a bind, which equals heat, which equals disaster. I would say you are cleared for takeoff.
It has been my lifetime experience that the Champion J8 was a random headache. I went out of my way to get Autolite 295's for my tractor.
Your B has no electrical system? No starter, no lights, no generator?
Does the flywheel have a ring gear, does the torque tube have a hole for a starter? I don't know the production history of what got in as standard when, plus there was a war on you know, maybe they reverted back to hand crank only for a time.
You got to know that a carb and the needle valve/seat problems can drive ya a little batty. Just as frustrating as the spark quest.
And then we will have a spat over inline filter and rubber hoses vs. original fuel bowl and steel lines. Some carb rebuilder outfits send an inline filter with each rebuild and a note saying "use this filter or warranty void". I think I read you do not have the stock fuel bowl shutoff? My advice, add an inline gravity type filter now. Then you will only have to take apart the carb for cleaning just once.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 8:14am
[BOLD] Also he has a ball valve on the gas tank with a inline filter instead of the glass bowl.[/BOLD]
I have found that in many instances, the inline fuel filter restricts the flow too much to supply the engine by gravity.
Make sure you have good fuel flow before you tear into the carb, and potentially waste time and money(or create other issues..)
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 11:21am
Well got the carb all straightend out and it started second crank no smoke no rattles or leaks she purrs like a kitten. Took it up and down the property a few times with no issues till it ran out of gas. Got a few errands to run then I'll get gas and run it some more. Thank you guys for all your help.
And yes no electrical system no lights no e start hole for the a start it's a 1942 hand crank only
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 2:48pm
When everything is working you can pull the mag and turn it 180. Then put the wires back where they were originally. Retime the engine with a timing light and you'll be good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 2:58pm
WHY! The wires are were they need to be the way the mag is mounted. It doesn't matter one bit if he leaves it that way or wastes time going thru this all again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 3:27pm
Did it occur to you that the plug wires would fit as designed if he's running OEM wires of the original length?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 3:57pm
It's alive! Very good. Another B stirs the dust.
I bet your status went up a few notches with the father in law.
Oil pressure good? Check the valve lash after running some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hamblin28 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 4:20pm
Has good oil pressure valve lash is good it's all good! The father in law had been riding around all day on it haha. Once I get time I will sand it down and paint it and try to restore it and make it look all pretty again. This is exciting thank you all for your help i couldn't have done it without you guys!
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 7:06am
Glad you got 'er running again!! The "B's" are nice little tractors....
'39 Model B
Tractors are cheaper than girls, remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 8:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 10:17pm
Hamblin I don't know how it can happen but the shaft to the mag gets bent. I know, it can't happen, but it does. You might check that, and at the same time check the bushings. If there is to much vibration it can screw up the timing. But I still think it's in the mag. timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 10:28pm
Dang, I don't know where the thread was that let us know you had it started. And I strained my brain for nothing. Good deal that it's running  Leon R  Cmo
