Model b wont start need help |
Page <123> |
Author | ||
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
If you get spark and you have the Center/TDC line in the center of the inspection hole it will have the fire line in the center of the inspection when running with a timing light. That is exact timing. At least it has been on all of these little Allis engines that I have worked on. From what you have posted timing is not your problem. |
Sponsored Links | ||
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Did you check timing by pulling #1 spark plug and sticking your finger in the hole as you crank? You can have the timing 180 degrees off. When you feel air coming out of plug hole 1, turn the crank until the screw on the crankshaft pulley is facing up. the look at where the rotor is pointing in the mag. It should point the the upper left wire terminal and to a raised post that is used to time the mag.
You can also squirt gas into the plug holes, the try to start it. LOL Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Hamblin28 ![]() Bronze Level ![]() Joined: 27 May 2016 Location: Williamsburg oh Points: 46 |
I'll check to see if I'm 180 off when I get home, I'll clean the carb and check the float adjustment to see if that's my problem and go from there
cpg ![]() Silver Level ![]() Joined: 10 Jul 2015 Location: Michigan Points: 246 |
I would see if you are 180 off by checking with the actual piston and valves for TDC on compression stroke as recommended. I'm not sure if the B has a specific bolt pattern on the flywheel or not but with some tractors you can put the flywheel on 180 degrees from where it was originally so since your engine has been out it is possible the timing mark on the flywheel is off.
He already checked that when he got spark at TDC and checked the valves on number one and both were closed. If he was 180º off one of the valves would have been open because it would have been the exhaust stroke.
I don't know of a four cycle engine that you can put the flywheel on wrong. The bolts are either staggered or crankshaft keyed to the exact position.
Unrelated information and could be helpful to newbies. When working on an engine of any amount of cylinders and you are unsure of the firing order you can remove valve cover or covers. Find TDC to number one with both rocker arms up. Mark above the plug hole #1
. Turn the engine over by hand very slowly and watch for the next rockers on a cylinder to both be up and mark #2 above the plug hole. Continue until you are back to number #1 and you have the firing order.
I believe everything is correct I'm 99% sure it's fuel related at this point. I had things come up today so I didn't have a chance to clean and adjust the carb. I will report back my findings and go from there thank you guys for all your help!
Another picture to compare. ![]() |
Well got the tires mounted and pulled it out of the been today. Pulled it twice and it smokes grayish blue while trying to pull start it, it started raining before I could mess with it too much. I pulled a plug and they were wet with a strong gas smell so I think I need to re check timibg. I think it's firing late, and clean the carb. Anyone have factory float setting on hand? There was some fuel coming out of the tiny hole in the bottom of the carb. Too much fuel? It smelled rich while we were pulling it. If the rain holds off tomorrow i should have the ole girl running again!
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
I know you said you "went down the line" and the sparks looked ok.
Look at Dick's picture. The #1 plug wire is at 10 o'clock on the distributor cap. The rotor turns clockwise, so next plug wire, at 2 o'clock is for cylinder #2. A guy I know wired his up with the 8 o'clock position going to #2 cylinder, wrong! All the tractor did was huff and puff and wheeze, sort of like you describe. |
Mine are the same as his. Anyway to tell if I'm 180 degrees out on timing? Maybe I'm on the wrong stroke?
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
When using ether to start by hand cranking, BE CAREFUL. You're trying to start an unfamiliar engine and with perhaps a timing issue and they have a history of kicking back like a Missouri mule. This tractor should start as easy with a 1/4 turn of the crank as they will with a battery. I would try to start it with single pull on the crank instead of trying to spin it by hand. The impulse spins the mag plenty fast to start it. On an engine that is obviously badly flooded, I would pull one plug at a time, stand to the side out of the line of fire and touch a propane torch to the plug hole. I've had them blow a pretty good fire out of the plug hole , but she ain't flooded no more. And I would do one at a time, so you could be sure to be standing out of the way. I'm serious about this hand cranking thing. Do a quarter turn starting at the 9-10 o'clock position with thumb tucked into your palm. I like to pull the engine up until feeling compression. then give a quick snapping pull. Not near as much danger of a kick back.
If you think your timing might be 180 degrees off just move your plug wires 180 each and try it. This'll start it if you are off 180.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
To set the float, just turn the carb upside down and make sure the float is level with the gasket surface. There is a cintered plug in the bottom of the carb to let excess gas out when it is flooded. Is the air cleaner plugged up? That will make it flood real easy. Disconnect the air cleaner and try it if you have it connected and aren't sure the air cleaner is "open". I have flooded my WC when I was tinkering with carb, mag and it wouldn't start again till I pulled the plugs and burned them off with fire and wire wheel. I think today's gas has something to do with varnishing up a plug that gets flooded. |
Like I said above. If you are 180º out when you get spark on number one plug which is above the magneto to the front. The exhaust valve would be open or one rocker arm would be down and the other one would be up. If both valves are closed then you are not 180º out.
I've seen some kick backs trust me I would never get in the way of that haha. We were pull starting it with the truck. I'll pull the valve cover and make sure I'm in time as well as double check the timing on the marks. I'll clean the carb and check the float to make sure that's all good. Not too sure what else to do at this point if all that checks out. I think it's a carb issue or something cause the plugs were soaked after we pulled it 100 or so feet. Seems like it's over fueling. Is there a way to set the jets and all that like run it all the way in then so many turns out to start with? Sorry again for noob questions this is all new to me
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
If it's just the float seat not shutting the gas off and allowing too much gas into the bowl or if the float is misadjusted too high it will flood the engine. Shut off gas. Drain bowl on carb. Turn on gas until you count to 10 and shut off the gas. The engine will run for a minute or two with just the gas in the bowl. My one-seventy will self flood if parked and the gas left on due to the float seat not fully shutting off the gas supply. I keep the gas turned off when parked for this reason.
1957 WD45 dad's first AC
PatrickBeth ![]() Silver Level ![]() ![]() Joined: 04 Oct 2015 Location: Wisconsin Points: 184 |
it's just a B thing, they are all like that. Have had mine for 25 years, rebuilt and overhauled last year, grand expectations of a non problematic hand cranking tractor when done, nope still the same tractor but with no leaks or smoke!
Mine don't like to start when remotely flooded. I don't set the mag off of top dead center. Find the fire mark on the flywheel, take the mag off, the mag engaugnent should be horizontal, if it's not, your cam is off, pull cover, check marks, they are real easy to see. If the engagement for the mag is horizontal, then put a plug in the mag in number one. Spin mag, see number one spark. Then put Mag back in tractor,you are set. Just got to learn the tractor, each have its quirks. Find a club, a B guy will help you, also find a mag guy have him give your mag a tune up! |
Make it simple, Take the plug out of #1 cylinder and turn the engine by hand till you feel compression in the plug hole with your thumb or finger blocking the hole. Bring it to the TDC mark or feel for the piston with a wire, It will stop moving at TDC for a bit. Then, take the cap off the the mag to see where the rotor is pointing. That is the number one wire no matter where in rotation it is, follow clockwise around using firing order to place the rest of the wires. If you want the wires to stay the way they are and it is out, you have to remove the mag and turn it till the rotor points to the wire you want to use for #1 cylinder.
An often missed and totally simple thing is, the drive slot for the mag, on the back of the governor housing HAS to be horizontal when at TDC. You won't have enough twisting available in the mag slot to get it in time if that slot is not horizontal at TDC. Edited by CTuckerNWIL - 03 Jul 2016 at 9:03am |
Tucker, read back thru all of his posts and you will see that all the timing checks has proven it was in time. He has had spark on number one at the time it was in the TDC line with both valves closed. That would prove he was on the compression stroke. When a cylinder is not on the compression it has to be on the exhaust stroke and to empty the cylinder of the exhaust the exhaust valve has to be open. I fail to understand with him proving this out why so many want to take him back to timing being 180º out. If his drive slot was not horizontal it could not fire and have the TDC line in the inspection hole. The only thing I can come up with is a confusion on locations. I would sure love to make a trip to see what is up but it is not an option for me.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
Do you have a hand crank? If so, try cranking it VERY slowly. If it starts or fires your impulse timing is off.
I agree with Dick, it would seem like the dang thing is in time. But, and here's a BIG BUT for me. The last time I timed a mag. was in 1958 and there seems to be some blanks in my memory. I do recall that I had to back the impulse up or something of that order to get it to start. Now if this so, it looks like it could be 180 off. I'm not disagreeing with Dick because he's made his living working on these things whereas I tended to gravitate toward big trks. I sure don't know it all and forgotten most of what I know. It's hexx to get old!.
I thought it sounded like he had checked everything for timing but he asked how to tell if he was off 180! I thought it easier to type a few extra words than go back thru 2 pages of stuff to analyze what all he had done. I have also gone over things before and thought, " oh, I already checked that", and end up finding something simple that I missed. I call that the distant star syndrome. If you look at it too long, you can't see it anymore so sometimes the best thing is to walk away and start all over another day or at least, get a different angle to the way you look at it. I wish I could be there too. Edited by CTuckerNWIL - 03 Jul 2016 at 2:35pm |
Well I worked on it for a few minutes today in between rain storms, I followed the number on piston to tdc with a wire both valves closed and the mag sparked #1 plug at the center mark. Its dead center in the inspection hole. So I shot a little ether in it and cranked it. It backfired out of the intake with a little fire ball. The air cleaner is off. So now I'm confused am I firing to early or what? I didn't think to look at what cylinder fired to cause the back fire. I retarded the timing just a hair and now if popped and shot a fire ball out the exhaust. It's flooded and I'm leaning to carb issues because fuel leaks out of the carb after maybe 10 cranks. Guess I'll pull the carb take it apart clean it and make sure it's set right to see if it will fire then fine tune it. Not sure how to post photos but I'm sure it would help you guys help me if I can figure it out
Maybe I need to pull the head off and front cover to check can timing and stuff. Like I said my father in law started this rebuild 9 years ago and has never got it to run. He's not very mechanically inclined and can't remember what he has checked and not.. I've worked on cars all my life but this has me stumped. I know a motor needs air fuel compression and spark. Suck sqeeze bang blow. If I get the barn all ready to go and it doesn't run I guess I'll pull it apart and start from square one. He had the whole motor off out new sleeves pistins the whole nine. I'm 23 and and this tractor is fasinating to me I want to restore this thing to it's former glory!
Hamblin, you need to leave the gas turned off once the carb. is filled. You can start and kill it a dozen times on just the carb. gas alone. And since you had these back fires, you have a timing issue somehow, someway. Did you switch the wires yet? There's no need to pull the head at this point. Pull the front cover if you think you need to. In fact it may be a good idea to take a look to satisfy your mind if nothing else. One thing for sure, stop pouring the gas to it. A little gas is good. A whole lot is bad. We'll keep the light on for'ya.
Once the carb fills I turn it off, I probably will pull the front cover is there any timing marks or anything to tell me if the cam and all that is timed right?? I have not had a chance to switch the wires due to the weather since its now out side under a tarp. I'll switch the wires tomorrow, so just switch it from 1243 to 4312? And see if it fires? Also one rocker arm is sloppy where I can lift it off the valve it's an intake valve and a couple others are a little loose what's the factory specs on how tight the rockers are? Also is there like an equivalent to a Hanes car manual for these tractors? I've been reading everything I can about this thing. This tractor will run if it's the end of me haha. Thank you guys for all the info so far it's greatly appreciated!
Man you are working in the dark,er rain! Yes, when you pull the front off the tractor you'll see the timing marks and I wonder if that isn't where the problem is. By taking off the front cover you're going to start at at the beginning and one step at a time should get you to where you want. If my memory serves me right Dick put some pics. on here showing the timing marks. Go back and look when you get it apart and make a comparison. With my new printer I can't send crap, but I'll get my daughter to send what the IT has in it. While not great it will give you an idea of what you're looking for. And it's no problem for us to do. Hope, Hope. Maybe I'll learn how to run the dang thing. My old one was no problem, had it down pat. We'll see.
Thank you guys very much, I'll do that just to easy my mind on the cam timing, I need to set the rocker arms for the valves man sure that's all correct, I'll pull the mag again and make sure I'm at tdc and set the mag, then pull the carb apart and clean it make sure it's all setup correctly then give it another go. Hopefully the weather breaks in the next few days so I can get back on it.
Page <123> |
