Model B Steering Support pin
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Topic: Model B Steering Support pin
    Posted: 21 Jul 2015 at 7:01pm
Anyone know what this pin behind the control box is for? It goes through the steering support tube, has cotter pins on either side. It's not drilled for the choke rod. Any ideas?
It is at the very top of the picture. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 7:02pm
I hate this laptop...
The pin is at the very far left in the otherwise turned over picture....
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 9:03pm
I never saw that before. Mine have a bolt and nut and the ground strap is mounted on the other side. Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2015 at 9:32pm
That is where the grounding strap is attach to when you have starter and lights on your tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 6:52am
The battery ground isn't in the picture, but it's above the control box. Does the starter have a separate ground? I thought it grounded through the frame...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2015 at 9:20pm
Yes, the starter is grounded through the torque tube. but the battery is grounded to the post in your picture with a bolt and nut. After the old rust and paint are removed. LOL Bob
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2015 at 5:47am
Could be the B may have been a handcranker at one time. The steering support post on a handcrank is drilled with a different set of holes than one with electric start. The throttle Quadrant on a handcranker was mounted where the electric box is mounted on a electric start B.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2015 at 3:56pm
The battery box has a tab that is bolted there on my 41 and 42
John
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
