|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| Model B Oil Pressure |
| Post Reply   | Page <12 |
| Morgan in AR   Silver Level     Joined: 25 Mar 2010 Location: Elm Springs, AR Points: 54 |  Post Options  Thanks(0)  Quote  Reply  Posted: 05 Aug 2016 at 6:33pm |
   Creston, keep us updated. I just overhauled a CA, and I have the same problem.
     If we loose freedom here there is no place left to escape to.  This is the last stand on earth. -Ronald Reagan
| CrestonM   Orange Level     Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |  Post Options  Thanks(0)  Quote  Reply  Posted: 05 Aug 2016 at 7:30pm |
   Will do. I'm thinking since I'm going to be really busy and maybe only home every other weekend or so, I may find a good pump and swap them. If it helps, great!! If it doesn't....well....I don't know...
| 49clipper   Bronze Level     Joined: 13 Aug 2023 Location: belleville,IL s Points: 7 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Mar 2024 at 11:57am |
   Interesting forum.   I did not have an issue with the oil pump leaking down until I changed oil to 10-30W.  Now the freshly rebuilt pump leaks down and will not show external oil pressure until primed.   I prime by removing the filter and using a small oil can pump into the port where the vertical tube goes and pump three or four times.   Quickly reinstall tube and filter and then I get oil pressure after about 15 seconds.  Now why.   apparently the external 1/4" tube leading out of the oil pump is bleeding oil back down that tube.   Why???   I made a fixture when I rebuilt the pump to measure the clearance between the cover plate and the rotor.   My manual says it has to be .00" or less.   I got mine down to .001" by using two .005" gaskets in the kit and dressing the cover down.  My new rotor sits proud of the pump housing by about .007-8" thousandths, just like the old one.  I see how the system works, but looking for the answer to this riddle.  From what I see, the filter cannot affect oil pressure.  the oil is pumped up the tube and gravity feeds the filter media and then just drains back into the case.  the line to the guage is just measuring the oil that gets dripped into the filter.  Its free flow.   Someone mentioned a Wix filter.   How is that different?
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Mar 2024 at 1:02pm |
   The filter material is PACKED COTTON... It does cause a few psi backpressure to the syste. YEs there is a 1/4 inch tube with a 1/8 inch orifice inside the filter housing that is doing MOST of the restriction, but the filter  helps.  20 years ago WIX made filters with paper material instead of PACKED COTTON and they lost pressure due to that. If your system drains back to sump, then you possibly have an air leak.. Look for a damp spot on the 1/8 inch pipe out of the bell housing, the 1/4 inch tube fittings, or the filter o-ring itself.. You have to get AIR into the system to allow the tubing to drain backward. | |
| 49clipper   Bronze Level     Joined: 13 Aug 2023 Location: belleville,IL s Points: 7 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Mar 2024 at 2:00pm |
   Yes, air is a must, but I have checked for those multiple times with no leaks.   For the filter to be part of the oil pressure result, it would have to be flooded all the time.  It is not flooded.  I filled the canister as much as I could, but it just drains to the crankcase with gravity flow and then would be partially drained by the next start.  My filter is filled with cotton, and I have tried two new filters with no change.   Amazingly, I went out to the shop today and started it and it showed oil pressure without any priming.   Wow, First time since I rebuilt the pump!!  I guess this is going to be a guessing game on oil pressure.   It is sort of a baffling system.  Thanks for your reply. | |
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Mar 2024 at 6:31pm |
   filter does not have to be flooded... It is like a WET TEE SHIRT crammed into a box.. Try to blow thru that.... PRESSURE on the top forces the oil down thru the WET COTTON and then it drains back to the sump... BUT on top of the filter, there is a few pounds of pressure....  On a good engine you have  15 psi at the gauge ... When they get OLD, you might have 5 psi at idle and over 10 psi at full throttle.
 Take a foot long piece of 1/2 inch pipe... Cut up a tee shirt into a 6 x 6 square.. Soak it in oil and POUND it into the pipe with a hammer and screw driver... Then BLOW on the end if it...  Edited by steve(ill) - 22 Mar 2024 at 6:34pm | |
| Dakota Dave   Orange Level     Joined: 12 Sep 2009 Location: ND Points: 3972 |  Post Options  Thanks(0)  Quote  Reply  Posted: 22 Mar 2024 at 7:54pm |
   My CA had low pressure when it locked up It had water changed to Ice in the pickup. When I took it apart the plug was missing from the front end of the cam. I got one and the spring from the Agco dealer when I put it back together. It had normal pressure. The only thing I did to the pump was replace the sheared drive pine in the rear end of the cam.
| john2189   Silver Level   Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 306 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 7:43am |
   Ok I’ve read this post a couple of times. What I get from it is that low or no oil pressure doesn’t effect the rods and mains since it is a splash system.  And that all the oil pump does is pump oil into the oil filter and cam bearings. I have not seen anything about how the oil pump pumps oil to the valve rocker arms and in the newer engines to the governor Edited by john2189 - 23 Mar 2024 at 7:47am | |
     '41 Allis B
 '45 Allis B '49 Farmall Cub '72 IH Cub | |
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 7:54am |
   No.... the pump does NOT pump oil thru passages in the crank and FORCE oil thru the main and crank bearings, like a regular car/ truck engine.. What it does is pump oil down a HOLLOW CAM SHAFT from back to front.. There are several pin holes in the cam that point at the pistons / rods that SPRAY the 15 psi oil at the  bearings and rod... the oil drips down into a hole in each rod bearing and gets into the bearing area.... Think of a SPLASH LUBE on the old Briggs & Stratton engines.. That is 85% of the oil... The other 15% of the oil comes out from the bellhousing thru the 1/4 inch pipe toward the filter... You will see a couple small tubes on the filter housing that go to the TOP END ROCKER ARMS and to the GOVERNOR Bearing.... The 15% oil in the filter is cleaned and dumped back to sump... If you PLUG the filter, you get 100% oil THRU THE CAM and SPRAY at the internal bearings... If you have a HOLE in the filter or NO FILTER, you allow too much of the oil to run back to sump and maybe only have 50% for lube and 50% lost to sump. | |
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 7:59am |
   Reread the 5th post from DICK L several years ago... He explains that BEARING WEAR does not effect the PRESSURE since the bearings are SPRAY LUBED... You have to have PRESSURE and OIL to make the system work. There are two BIG differences in the "B" engine compared to a TRUCK... -- One is that 15% of the oil goes thru the filter and dumps to sump on the B.. On a truck 100% of the oil goes thru the filter and then LUBES THE BEARINGS. --Second, the "B"  SPRAYS the oil at the bearings, similar to a SPLASH LUBE mower engine, as compared to a truck that FORCES OIL PRESSURE into the bearings thru oil galleys. Edited by steve(ill) - 23 Mar 2024 at 8:09am | |
| john2189   Silver Level   Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 306 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 8:10am |
   Ok I kinda get it now.Its been years since I’ve rebuilt a B engine but I have an old engine from a C. I guess I will have to take it apart so I visualize it better.
     '41 Allis B
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 8:12am |
   Drawing in manual with circles around the SPRAY HOLES in the cam shaft.. You NEED flow thru the cam and spray out of these holes for bearing lube... Dick says the oil is THROWN OUT of the cam by centrifugal force... I like to think there is some PRESSURE in the cam and it is SPRAYED out of the holes.. Note items 10 and 11 at the front end of the cam..That plugs the hole and helps maintain SOME pressure inside the cam oil passage. Edited by steve(ill) - 23 Mar 2024 at 8:15am | |
| BrianC   Orange Level Access   Joined: 16 Jun 2011 Location: New York Points: 1619 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 8:59am |
| Re-read this post and others. One thing I need to  know is, where is GeraldJ? He always had good info to add. | |
| Les Kerf   Orange Level   Joined: 08 May 2020 Location: Idaho Points: 1384 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 9:11am |
 Ummm... doesn't some of that oil still go to the top end even if the filter is plugged? | |
| steve(ill)   Orange Level Access     Joined: 11 Sep 2009 Location: illinois Points: 88508 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 9:17am |
   YES... my point was if the FILTER is plugged, then no oil is dumped to sump... I  goes thru the cam and it goes ( at the filter housing) thru the 1/8 inch tubes to the rocker arms and governor.
 Gerald left in Jan of 2021 ............ ??? Edited by steve(ill) - 23 Mar 2024 at 9:20am | |
| Les Kerf   Orange Level   Joined: 08 May 2020 Location: Idaho Points: 1384 |  Post Options  Thanks(0)  Quote  Reply  Posted: 23 Mar 2024 at 9:47am |
   I re-read the manual and noticed that the oil pressure relief dumps the excess oil to the inside of the camshaft where it can still be utilized; clever. | |
| IBWD MIke   Orange Level     Joined: 08 Apr 2012 Location: Newton Ia. Points: 4132 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Mar 2024 at 9:25am |
| Gerald left in Jan of 2021 ............ ???[/QUOTE]I believe Gerald J. should be added to the Memorial section. I had forgotten about him, he did have lots of knowledge. | |
| HudCo   Orange Level     Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3948 |  Post Options  Thanks(0)  Quote  Reply  Posted: 24 Mar 2024 at 11:24am |
   take the pickup tube off and replace it , i belive it is 3/8 npt about 8 1/2 inches long  ,ifinley replaced mine it had a tiny crack in the pipe up close to where it threads inthe block and would suck air .     i had done the pump when i put a clutch in it didnt help worked the fiilter base didnt help filled it a gallon over full and had oil presure but would loose it going ing down a hill  .    i ran mine that far over full for two years cnat believe the main didnt leak
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
