Model B horsepower & carb question
waynem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 8:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 8:34am
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 4:31pm
A little hard to see everything I need to see to date every detail but it looks like a 38/39/40 combo. I like that 37/early38 Zenith fuel cutoff jar type sediment bowl.  The speck plate manifold is a correct for the age original. The early B covered spoke steering wheel is nice and correct.
   She is a cutie.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 5:05pm
And the correct police might let you know there wasn't a "B" decal used till the CA came out I believe. She is a cutie.  Ken, it's a B, what else would you call it. LOL
Edited by CTuckerNWIL - 17 Aug 2011 at 5:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 5:16pm
I'm not real shur exactly when the gas tank with the rear mounting strap became standard. Early Bs up to 1940 for shur had a bottom rear mounting bracket and no top rear strap.
   Handcrank Bs used the long A & S blue and white hood transfers and no B on the nose.
   Are you running a underhood muffler or a straight pipe? Either one could be considered right on a handcrank B
   Does it have a pto & hydraulics  or a pto delete plate on the back of the transmission?
A good shot from the rear will tell me if the seat back support straps  are 38 or 39 and up. 38s are wider than standard.
    Curious to see what vintage the wheels and wheel clamps are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 5:27pm
Ken, was the shape of the rear strapped tank different than the early tank? The picture looks like the tank is too far forward or doesn't fit the support just right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 7:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 7:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 7:05pm
Everyone thanks for the input I am learning alot. I am running an underhood muffler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:22pm
Well,  the rear wheels, clamps and rims are not of the two early types used on early handcrank Bs. This clamp and 4 bump rim system became standard sometime in 1940 productiom along with the 5 hole bolt on wheel front wheels.  The seat back supports are the standard 39 and up narrow ones.
   When you restore a B and need a replacement part, pretty near everything from any year B and some C parts will interchange by bolting in or on.  Main thing is get it to run and drive. Call it a 40 if you want but overall it looks more like my 39s  than any 40s I have.  Have fun with it and be careful when cranking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:25pm
I found one of those PTO delete plates at Dad's when we went through his garage stuff. I wonder if the 47 C he used to have, had that originally and he added a PTO to it??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 9:44pm
C Tuck
    I did notice the gap between the rear of the gas tank and the top edge of the tool box. I have not tried to retro fit a strap tank to a handcranker tool box so I can't comment. To whoevers credit though, the hood line and the gas tank seam line up perfectly straght front to back.  I can't see in the pix how the tank strap is fastened to the tool box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2011 at 10:01pm
Thank you to all for helping out I think I will call it a 39. I do like the other Allis Chalmers decals my self the ones with the longer A and C & will want to replace those. I am taking it to my cabin in Upper Michigan & am going to put it to work this weekend hauling firewood. I plan to use this tractor for what it was made for work. Again thanks to all I appreciate the help & will not hesitate to ask more questions as needed.
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2011 at 8:30pm
Good looking tractor! Enjoy it and take care of it.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
mrheartbeat1964 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrheartbeat1964 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2016 at 9:13pm
how much on a kit for a zenith 206989   this is on my 38 B, thanks billy norman my address is 110 chandley road,kingston,tn 37763 for shipping
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2016 at 8:06am
To buy parts for your tractor like the carb kit, go to the top of the page and click on (parts etc) tab. These are guys that help support this site and sell about anything you might need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2016 at 8:22am
Our kit runs $34.50 + the ride if interested.
Steve@B&B
bb-customcircuits.com
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 6:35am
anybody notice the Tow Vehicle? Wow and I thought I was crazy!
If you're gonna just work the tractor, it shouldn't be that hard to add hydraulics. Just remember a B is a light work tractor. I'd put some weight up front if I could.
A safety note, check to make suuure that your magneto kill switch works, and I have a long story about what can happen if the clutch pedal is allowed to go past the stop while running. So check to see if it's possible for it to go past the stop. If it does, PM me and I'll tell you the simple fix and the story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrheartbeat1964 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 8:25am
On my 38b i have just had it for 2 weeks and got it running and driving. I really like it with all the other tractors me and my son have but got a question. Does anyone have a set of brake locks for hand brakes or did they not have any from the factory. Just checking and thanks for any help
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 10:18am
They had them originally. Little flip over levers that attach with the front bolt on the brake covers. My '39 still has them but I don't have any spares.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrheartbeat1964 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 10:26am
Would you send me a photo of them so I will know what they look like and I will try and find some. Thanks Billy Norman
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 12:26pm
Originally posted by Ken in Texas Ken in Texas wrote:
Tall Spindle adjustable front axles became available in 1940. Most if not all 40s with this axle also had 5 stud adapter hubs and 5 hole semi-dish reversable rear wheels.
Is your 40 equiped this way?
   That is a neat picture . There are a lot more bigger cry babies then little ones .LOL
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 2:26pm
I'll take some pics and post them for you, when it quits raining here!.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 2:39pm
Originally posted by JimD JimD wrote:
Not sure that Jeff is thinking of us, but I have been very happy with our kits.  Here's a photo of one sprawled out.
Hey Jim, whats the cost of your kits?
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrheartbeat1964 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 2:53pm
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2016 at 7:20pm
Billy. Send me a Private Message with your e-mail address and I'll send you some pics.  For some reason the site won't load my pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 8:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 8:58am
Here is the second pic of the latch locked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 8:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrheartbeat1964 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2016 at 12:30pm
Thanks for the photos that will help me
