Manifold question
Dennis IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Topic: Manifold question
    Posted: 03 Mar 2010 at 10:43pm
The last time I put a manifold on a tractor the manifold gaskets fit on the back of the manifold just enough to keep them in place while fitting the manifold to the engine. This time they seem to fit a little loose. does anybody have any tricks they use to keep them in place and straight until I can get the manifold bolted on? a little dab of glue maybe? what do you guys think? I'm looking for a few suggestions thank you.   Dennis.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 4:54am
Dennis, I always use a thin coat of grease. Works well and has never caused me any problems.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 5:00am
Just a dab of Permatex High Tack will hold them.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 6:29am
Like Bob and Jeff I have used whatever sticky stuff was closest to me, grease, Hi-Tac, a drop of blue glue, doesnt take much and you dont want to use much. Another thing you can do on certain manifolds that have a decent fit to the cups is to slightly pinch the edges  cups so they have to be pushed on the manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 7:32am
I second the Hi Tack. If the manifold/head surfaces are a little rough, the Hi Tack will help seal it. Gas dissolves silicon sealer in minutes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 9:44pm
Thank you gent's all good advise! I figured you guys could give me a few good options to try and I've never been let down once. Thank's again all!   Dennis.
