magnito cutout
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: magnito cutout
    Posted: 17 Jun 2010 at 5:24pm
I have one B that has a 72 inch belly mower that we use to cut a field. PUts a good load on the tractor. Old mag would cutout after 1 hour. Used it that way several times. THs morning i installed a new coil and condenser. Fired up on the first roll. 2 hour later... spit, sputter, and die...Outisde of mag is hot.. Has anyone put a reversed fan on a B or C, WD ??  Im thinking a reversed fan would push air thru the radiator,  keep the mag cooler, and proabably blow the grass/ weeds off the grill.. any ideas??
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 5:47pm
You just have a bad coil that needs replaced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 6:17pm
coil and condenser are brand new yesterday... im thinking of changing the condenser again. ever heard of a heavy duty condenser ?  I got to believe the coil is good ???????
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 6:25pm
I have seen bad condensers new and that is a cheap thing to try first.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2010 at 6:57pm
Steve,  What you describe is a coil or condenser problem.  You installed new coil and condenser.  May be they are not up to par.  As said above try the condenser first cause that is the cheapest.  What you say about the reverse fan makes sense but what is happening should not be happening with a new coil and conderser.
Perhaps Steve NJ could be helpful.
Can't have my favorate especially yours not running right.
Good Luck!
Bill Long
ps:  let us know how it goes
This page was generated in 0.111 seconds.
