Losing me mind. B starter setup
Message Reverse Sort Order
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Topic: Losing me mind. B starter setup
    Posted: 23 Feb 2011 at 8:56pm
Here is a pic of Lil' Allis's push type Delco Remy starter switch area:
Don't know if this helps any, good luck Jim, we all have those days.....
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 6:51pm
Steve, I think being the brunt of all the short jokes has gone to your head. Maybe the pills have something to do with it but I don't believe you are 3'1".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 4:38pm
Jim,
My weight hasn't changed much since high school, so I don't think the these pills have any effect on weight, but I was 5' 4"/148. Now I'm 3'1" at 149.... Waist is the same, had to shorten the pants tho......
Steve@B&B
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 4:21pm
What had me going is that out of the 30 or so B's I've salvaged out, may 5 had the original setup.  I've gone to far as to talk to a local shop about reproducing the little pig-tailed pushrod.
Steve,  will the pill stunt my growth outward?  I good at 6'.  In the 6th grade I was 6' and 185 lbs.  I graduated at 6' and 185 lbs.  Got married a year later at 6' 185lbs.  Then something happened?  6' and 250lbs and I think my brains slumped into my gut.  Can't remember a durn thing and my mind is always on my next meal :)
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 4:13pm
That's okay Jimbo. They have pills for that. I take em' to keep my sanity sometimes. The drawback to them is they stunt yer' growth. That's why I'm working on a G model now. I can get on that one easier without to much help....   LOL!!
Steve@B&B
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 11:20am
Some gas tanks have  a depression in bottom of tank for longer lever. may be on 10 and 12 models not sure.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 10:56am
Could be maybe I just haven't looked enough, I bet you a dollar next time I go to a show I will see them all over.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 10:51am
My CA has the pull rod with the switch on top. I thought B's went that way after the CA was introduced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 8:28am
I never saw a switch on top like that
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 2:49am
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 4:59pm
For a minute there I thought you were looking at an English B since they had, I think what they called, a Lucas set-up with solenoid and key switch.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 2:19pm
Your not the only one who has those "Kinda" day's!!
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 1:06pm
Wow, college education failed me again :).  I see the photo now.  Though it won't help my costomer since the lever/switch is not really shown because it is on the bottom.
I think I will go back to bed now.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 1:01pm
Jim -  It's OK- No pun intended.
   Like the man above said, your on the wrong page.
   Next page. Electric Starting. B-IB-C.  Picture stinks but the part numbers are all there for the rods. 5 of them. Brackets. 3 of them. Levers. 2 of them and, 2 switches. a Delco and a Auto-lite.
  A pretty decent photo of the Starter/switch with the lever is on B-C page 40 of AC form SM3 "Knowlege Means Power".  Covers G, B&C, & CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:25am
I have two starters with studs instead of the contact.  I think they are autolite starters.
Tramway Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tramway Guy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 10:55am
You have the picture for the B-125 stationary engine.  The 'B' tractor is on a different page.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 10:04am
OK, so I've sold hundred of those starter switches on the side of the B starters.  Sent a starter to a customer, and he couldn't figure out how it went with the rod and such.  Finally figured out he was missing the starter, switch, rocker lever, and rod.
So.... I thought I would print him a pic of the whole setup from the parts book.  It's not there!  It shows a solenoid.  Pulled a parts book from the shelf, same thing!
I'm never ashamed to learn something new, but have I lost my mind?
I was unaware any B's ever came factory with solenoid starter setup.  I know there was a rod you pushed with your heal, and one that pulled on the later B's, but unaware of a solenoid setup.
Anyone care to comment on this (not on my mental state)?
JImD
