Looking for D19 diesel engine parts |
Page <1 234 |
sampsonrepair ![]() Bronze Level ![]() Joined: 07 Jan 2025 Location: Wisconsin US Points: 41 |
Precisely. If someone wants a trailer queen, then none of that matters. I just feel a lot better now that we are moving away from the diesel all together. Do you have any idea if my diesel flywheel can be used with a gas engine? Crankshafts are the same, rear plates are the same, clutches are the same, front pulleys are the same. Starter, ring gear, and flywheel are different part numbers. I'm guessing the gas flywheel is perhaps lighter? But I can't think of any harm in bolting up the diesel flywheel--unless there would be some weird external balance issue or something. I wouldn't think so, given that the cranks are the same. I have a lead on a running D262 out of a D19 I'm pursuing and another out of a C2 combine. The engine out of the D19 definitely sounds like the less complex of the two options. But the seller is keeping his flywheel and starter.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21112 |
Flywheels interchange. RING GEAR TOOTH COUNT IS DIFFERENT I THINK.
Edited by DrAllis - 12 hours 44 minutes ago at 1:14pm |
Page <1 234 |
