looking for a heavier rod than the diesel buda rod |
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Oct 2010 at 6:38am |
bent one this makes two sets . looking for something stronger to handle the pressure with a 2 inch rod journal
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22089 |
Make it easy on yourself.....first, use the rods that are NOT rifile drilled for oil pressure to the piston pin bushing.....two, have your conn rods heat treated like the diesel superstockers used to do.....they won't bend anymore if done right.
wi50 ![]() Orange Level ![]() Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
I've "boxed" rods in the past. I cut metal to fit in the bream and tig welded around it, ground all original flashing off and then shot peen and heat treat, though for the cost of the rods all the work and outside costs one can about buy a set of billet ones.
I made a set of aluminum rods from 7075-t6 but what a PITA
How long are the Buda rods to start with?
Edited by wi50 - 03 Oct 2010 at 8:54pm |
Ken(MI) ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
There is no substitute for FORGED 4340, go big o
buda rod is 7 3/8 long 1.27 rod ratio 15.3 comp ratio. ran a ratio of 1.25 before on 11.1 comp c farmal rod broke cranks but didnt bend rods alot weaker looking rod.the buda rods were reconditioned and shot peened . no other heat treating than what i would have thought they would have been from the factory . I will see if I can get a set heat treated . Is cryo better or not as good. I am wondering if aluminum would be better to handle the shock but to get them beaffy enough could cause some interference with the camshaft.
Edited by mlpankey - 04 Oct 2010 at 7:26am |
Mitch, Cyro is smoke and mirrors in my opinion for most alloy steels, good heat treat practices will yield excellent results and good grain structure without cryo treatment, but it is very important that the critical temper range be avoided for this type of part. Aluminum rods have a very short life span, I would not consider them for this application. I'm not sure who forged the Buda rods, but if they say Atlas on them, chances are that they are made form 1040 sbq forgings, and the mechanical properties are limited, and re-heat-treating won't do much for them. I would persue a 4000 series alloy rod, preferably forged, but even a machined rod from the right material would do well for you.
Edited by mlpankey - 04 Oct 2010 at 8:03am |
firebrick43 ![]() Orange Level ![]() Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Second the cryo, it doesnt do anything for a regular rod. It might, and that is a big might help stabilize some types of steels after heat treat but the amounts shown to help are so minuscule it could be just natural variation in the material, not worth the money in my opinion.
Bee ![]() Orange Level ![]() Joined: 14 Jun 2010 Location: NC Points: 201 |
Try Joe Mondello.
http://www.mondello.com You will see his name on many Don Garlits Dragsters. |
Bob, North Carolina
1949 B |
Here you go, straight out of Ford service info: Rod bearing I.D. 2.5005-2.5025, center to center 7.130, piston pin bushing I.D. 1.308-1.309.
My Buda rods say "Atlas" on one side and Buda on the other.
I thought Joe Mondello was known as Mr. Oldsmobile. Edited by Brian Jasper co. Ia - 04 Oct 2010 at 2:43pm |
joes just up the road a piece from me.
When it comes to engines Joe can do anything. He does loves Olds but he also rebuilds about anything. He has been porting cylinder heads for 57 yrs. He has a fully equipped shop including dyno, flowbench, and cryo.
Bob, North Carolina
1949 B |
He was on Power Block last season. Sounded like he really knew what he was talking about.
6.0 rods have larger journals. V10 rods measure 53.049MM to 53.027MM. I don't have my fractional to metric conversion chart handy, and the length is not given either. Looks like the pre powerstroke 7.3's are also 2.5. I'm not having any luck finding 6.9L diesel dimensions. That might be another way to go.
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
mlpankey and Brian Jasper
6.9L IDI, 7.3L IDI 1983-1994 The same connecting rod (c/n 1816619C1) was used for all the 6.9L and 7.3L IDI non-turbo apps i found this on the net hth B:-) Dnoym mlpankey |
mlpankey tried to put this in the
last post but it didn`t show up http://www.standardcrankshaft.com /connectingrodcatalog.html?sid=4272 B:-) Dnoym |
thanks dynonm. doesnt look like theres anything in a automotive app.
I would just about bet that those Buda rods are nothing more than 1040 steel as I mentioned above, I sunk many dies for Atlas Drop Forge in a previous life, and rarely saw material spec.s for anything better than that. The standard order of the day was to forge, re-heat, hot trim, and quench in brine, followed by a tempering cycle, a full annneal, followed by a carefully controlled heat treatment may yield a stronger part, but don't waste the money to cryogenically treat them, a properly executed heat treatment of this steel will yield a 95% or better transformation to martensite, and the remaining 5% won't make it or break it for you.
thanks , ken I guess its time to call greg for a set . I had a set of forged customs but after being machined they werent heat treated and are bent jp holt said he had some he used in a 7.3 powerstroke that hadnt been treated and they did the same so he went with greg cunningham .
I saw that 6.2 GM diesel has 2.25 big ends. Still too big? I tried finding specs on 5.9 Cummins, but only saw the small end listed as 1.5".
d17brown ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: farley iowa Points: 1729 |
i use farmall 350 rods with 325 psi compression and no bending or breaking in 5 years
Edited by mlpankey - 06 Oct 2010 at 11:30am |
