Loader on a D15 series2
toddkatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toddkatz Quote  Post ReplyReply Direct Link To This Post Topic: Loader on a D15 series2
    Posted: 02 Aug 2017 at 6:50pm
I found a allis 500 series loader and the seller says plugs into back of tractor. I have a quick disconnect coupler on back. Do I have enough hydraulics to operate or do I Need the pump on front end?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 7:54pm
The 500 Series loaders are for tractors with 'live hydraulics' like a D-17 Series IV. They use the tractor hydraulic oil reservoir and on-board hydraulic valves.
A D-15 needs a 400 series loader. It has the front mounted hydraulic pump for 'live hydraulics.
The oil reservoir is in the L/H loader frame, and the bucket control valve and the lift control valve are mounted on the L/H loader frame.
Gary
Joe(TX) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 12:26am
The 500 loaders also could be bought with the oil reservoir in the frame using a front pump.
The 500 was made for the D17 through 190 tractors.
The 500 used larger cylinders.
Pressure is no problem. The speed will be slower using the remotes.
This page was generated in 0.075 seconds.
