Loader Model # ???
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Loader Model # ???
    Posted: 28 May 2024 at 3:29pm
What model loader do I have here ?
Edited by Macon Rounds - 28 May 2024 at 3:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 3:30pm
It was on an Allis 175.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 5:03pm
We had 500 that looked like that. Looks like the tilt cylinders are on the bottom like a 500
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 5:04pm
Bucket tilt
1984 80780
1957 D14
616 tractor
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2024 at 8:49am
had one like that on my 175, it came off a 200. think it was a 519??...Harvey
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 1:02pm
Been a long time but I'm thinking it's a 400 series. If memory serves the 500 had the hydraulic reservoir built into the uprights, the 400 didn't
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 4:54pm
Boss Man
Actually it is the other way around.
The 400 Series Example 445, 414, 415, 417, have the hyd. oil in the L/H upright and the Tilt and Lift Control Levers mounted on the left side.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 6:29pm
Someone recently had scanned a page from the loader price book that showed all the different models and versions. I submit that there was a 500 series with a tank in the left tower, a front pump and a control valve. This loader would have fit older D-17's and all D-19's with a change to the rear axle brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 6:35pm
This one has the tank in the left loader bracket but it was never used.
It was on a 175 and they used tractor hydraulics and control valves.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 6:42pm
Dr.
You are right. The Allis Parts Catalog D47 does list A Model 517 and 519 along with the 400 Series 414, 415, and 417 with the Frame Hydraulic Oil Reservoir.
G
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 10:08pm
Our D-17 has the loader setup Dr Allis listed.  We had it put on by our local Allis Chalmers dealer, around 1970.
We still use the tractor and loader daily.  Never had any problems with the frame cracking. Replaced the pump, control valves and rebuilt the cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2024 at 10:22pm
I have a 460 and the sump is in the left hand side upright.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 7:50am
Edited by Macon Rounds - 02 Jun 2024 at 7:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 7:57am
The easiest way to absolutely determine a 400 series over a 500 series, is the cross bar that goes over the top of the hood that connects the vertical towers together. On a D-17, you must remove the cross bar to remove either engine hood. The cross bar is very close to the hoods. On a 500 series the cross bar is raised up probably 3 inches more (taller towers) allowing you to remove hoods without unbolting the cross bar.
Edited by DrAllis - 02 Jun 2024 at 8:25am
This page was generated in 0.039 seconds.
